2002 tacoma race build
Discussion in '1st Gen. Builds (1995-2004)' started by linked2002, Aug 17, 2011.
  1. Aug 19, 2011 at 12:38 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  2. Aug 19, 2011 at 12:39 PM
    linked2002
    linked2002 [OP] Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    with the steering rack it is supposedly no more than 17" before you start breaking racks. so this weekend hopefully i can get the upper arms on and get to cycling. ill let you guys know numbers once i do.
  3. Aug 19, 2011 at 12:43 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  4. Aug 19, 2011 at 12:48 PM
    linked2002
    san diego
    haha sorry again for not being able to update as much as i would like to. i really only get to be under my truck and balls to the wall into fabrication on this thing on the weekends so i can only update after them. again i promise yall that ill get more pics up once more major shit happens to this beast.
  5. Aug 19, 2011 at 5:32 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Mike pass the popcorn:cool:!!
    6" over and Linked rear! That's awesome man :thumbsup:
    What size coilovers you running up front & rear?!
  6. Aug 19, 2011 at 6:20 PM
    stephen11ty7
    stephen11ty7 Well-Known Member
    Stephen
    Villa Park
    07 white taco
    Total Chaos 2" LT, Icon coilovers
  7. Aug 20, 2011 at 7:43 AM
    linked2002
    san diego
    King 14x2.5 in rear and king 10x2.5 up front. Eventually 2.0 bumps all around and bypasses.
  8. Aug 21, 2011 at 7:03 PM
    linked2002
    san diego
    Well I got the upper rear link on and cycled. Ill know travel numbers once I get the bedcage outline in. Pictures to come tomorrow. Changing up the bushing pivots on the frame and though and just going with heims. From as high up as we could lift to setting axle on the floor (approximately 28-32 inches), I had 10 degrees of pinion angle change and 1/2 inch of plunge.
  9. Aug 22, 2011 at 8:23 AM
    linked2002
    san diego
    here you guys go. a little bit of insight into the rear end. the links wouldnt go any higher due to the lower hitting the jack stand holding the truck up. have some funny pictures coming later.
  10. Aug 22, 2011 at 8:26 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    when you get a chance can we get some close ups of all the work? like the front arms, the rear axel. all the cool shit:)
  11. Aug 22, 2011 at 8:35 AM
    linked2002
    san diego
    ill be doing that once i get done with the plate work to the frame and get closer to completion. no point is spoiling all the fun on my end by keeping you guys waiting on the goods hahaha.
  12. Aug 22, 2011 at 10:39 AM
    linked2002
    san diego
    buddy finished gutting the insides, and upon him getting out of the truck with my sub box it removed all rear weight off the jack stands and the truck started tipping forward. thank goodness there was a tire under the front end that stopped the truck before it slid off the front stands.
  13. Aug 31, 2011 at 10:07 AM
    97yota4wd
    Eric
    Mesa, AZ
    any updates?
  14. Aug 31, 2011 at 10:21 AM
    linked2002
    san diego
    nothing yet man. my leg was put back in a cast so im sortta moving a bit slower. only update i can give you guys is that there was fucking surface rust on my upper arms last night that made me mad. very very mad! hahaha
    EDIT: that isnt true at all! i said screw bushings on the uppers and went full heims, picked up some upper pivots from ruff stuff. that is about all ive got for now. i need someone in san diego to come on over and help me out this damn saturday! beers on me.
  15. Sep 6, 2011 at 7:19 AM
    #35
    linked2002
    san diego
    got my uppers all welded up and ready to be placed on. waiting on pivots to get here then its all going together. rear upper link had some setbacks today as i was a moron that forgot to thread a hiem in before i welded the bung in and it trashed the threads.
  16. Sep 6, 2011 at 8:07 AM
    #36
    mjp2
    NJ
    Might be overkill but have you considered welding a small gusset between the tubes where they meet the uniball cup?
  17. Sep 6, 2011 at 8:49 AM
    #37
    linked2002
    san diego
    no sir. i will actually be wrapping the front of each uniball cup with some 1/8th plate.
  18. Sep 6, 2011 at 9:37 AM
    #38
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  19. Sep 6, 2011 at 11:04 AM
    #39
    mjp2
    NJ
    Even better. :thumbsup:
  20. Sep 6, 2011 at 11:05 AM
    #40
    linked2002
    san diego
    oh you know... im not fooling around with this truck. not worth the hastle. just doin it right the first time haha.
