2002 tacoma race build
Discussion in '1st Gen. Builds (1995-2004)' started by linked2002, Aug 17, 2011.
  1. Jan 28, 2014 at 8:40 PM
    #461
    linked2002
    linked2002 [OP] Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    HUGE hanks goes out to jason (jberry) for the fuel pump. Got the truck running today to find out the fuel pump isn't pushing shit. Soon!!!!
  2. Jan 28, 2014 at 8:54 PM
    #462
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I expect you should have it Thursday, Friday at the latest.
  3. Jan 28, 2014 at 10:22 PM
    #463
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    What was the issue with no spark ?
  4. Jan 29, 2014 at 7:42 AM
    #464
    linked2002
    san diego
    Pin 9 on the ignition module wasn't receiving any power. Chased the wire back to the cab and it ends up in a connector that is no longer used. Applied switched voltage to it when the key is in the on position, fucker turned right over with some carb cleaner into the intake. Injectors were tested and are pulsing. Only thing left is the fuel pump isn't picking up as it should.
  5. Jan 29, 2014 at 9:02 AM
    #465
    TC yota
    Tyler
    Escondido
    Ha
    Oh cool , also make sure it's not you fuel pressure regulator , That could also cause low fuel pressure
  6. Jan 29, 2014 at 9:39 PM
    #466
    linked2002
    san diego
    It is telling me in the manual that if it's bad the whole plenum has to be removed. Their joking right?! I just want it to run!
  7. Jan 29, 2014 at 9:49 PM
    #467
    TC yota
    Tyler
    Escondido
    Ha
    Yeah it's under the intake manifold
  8. Jan 29, 2014 at 11:35 PM
    #468
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's really easy to remove. 4 bolts on the TB, pull your hoses, a handful of bolts for the upper, and a handful of bolts for the lower.
  9. Jan 31, 2014 at 8:56 AM
    #469
    linked2002
    san diego
    Well today should be the day. Fuel pump came in the mail ( thanks again jberry) and replumbed the cell disconnected overflow and fuel came pouring back into the overflow line. Looks like the fuel regulator is 100% shot. Picking one up today after class.
  10. Jan 31, 2014 at 11:59 AM
    #470
    TC yota
    Tyler
    Escondido
    Ha
    Not necessarily, at idle you will be getting quite a bit of return fuel , easy trick is to try pinching the return line and see if that helps
  11. Feb 1, 2014 at 10:30 AM
    #471
    linked2002
    san diego
    Well fuel pressure regulator allowed her to fire right up and even drove her outta the shop. In need of a serious alignment and cannot figure out why my diagnostic lights like the cel light up, but no rpm or speedo. Also once it warmed up it started stumbling and threw and iac circuit code. Bah!
  12. Feb 1, 2014 at 1:24 PM
    #472
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Did you disconnect the ECM at all? I had a similar problem when I put the engine back in and one of the connectors on the ECM wasn't fully seated. Threw a few weird codes that made no sense.
  13. Feb 8, 2014 at 6:40 AM
    #473
    linked2002
    san diego
    Hmm. I've checked all connectors numerous times but it doesn't hurt to do it once more. I'll go through the truck today and verify I'm all plugged in. May have a lead on an IAC for 70 bucks so we will see.
  14. Feb 8, 2014 at 1:19 PM
    #474
    linked2002
    san diego
    Tada!!! She runs and idles now. Woot!!! Seats then it's test run time
  15. Feb 8, 2014 at 1:27 PM
    #475
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Nice!
    What was the fix
  16. Feb 8, 2014 at 1:29 PM
    #476
    linked2002
    san diego
    Ended up being the throttle position and iac valve were both shot. Lesson learned. Drive it up and down harbison canyon. She rides nice.
  17. Feb 20, 2014 at 11:22 AM
    #477
    linked2002
    san diego
    well the truck is up for sale.
    taxes fucked me this year and i cannot afford to have as many toys as i want to (go figure). she runs, she drives, just needs seats and the registration taken out of non- op.
    if interested in purchasing please drop me a pm.
  18. Feb 20, 2014 at 12:34 PM
    #478
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
  19. Feb 20, 2014 at 1:27 PM
    #479
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    after all this work :(
    just keep it :(
  20. Feb 20, 2014 at 5:25 PM
    #480
    linked2002
    san diego
    i wish i had that option.. but i keep this truck and loose my livelyhood, or sell it and build another later. its just a material thing after all
