2002 Tacoma: Removed & Replaced Radio
Discussion in '1st Gen. Tacomas (1995-2004)' started by AlphaOmega310, Sep 7, 2011.
  1. Sep 7, 2011 at 9:41 PM
    AlphaOmega310
    AlphaOmega310 [OP] New Member
    South Bay
    2002 PreRunner SR5
    1. Original 2002 Tacoma Radio
    2. Remove the 3 control nobs and faceplate
    3. Carefull remove black plastic molding and the remove the radio
    4. Connect the 2 Blue Toyota connectors to the Alpine Adapter harness
    5. Connect PAC-TR7 bypass: This device will allow you to view DVDs or videos from your iPhone while the truck is in motion.
    TR7 wire --> Alpine/Radio harness
    Red -->Red (accessory) wire on radio harness
    Black --> ground black wire
    Green --> Trigger input (Blue/white wire)
    Blue --> 12v+ Yellow/black foot brake
    White --> 12v- Yellow/blue parking brake
    6. Connect the Alpine W910 and put everything back into to its original place. The new head unit fits perfect with the truck and looks good
    This whole thing took about roughly about 2.5 hours. :eek:
  2. Feb 4, 2013 at 7:44 PM
    CyberGolem
    CyberGolem Member
    I smashed the rear taillight on the driver side and have coated the bottom with some New England rust.
    Does it tilt upward so it's easier to see?
    ~CG
  3. Feb 11, 2013 at 2:47 PM
    AlphaOmega310
    South Bay
    2002 PreRunner SR5
    Yes the head unit does tilt upwards for better viewing positions
