2002 Tacoma Rusted Frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by kskok, Oct 2, 2017.
If anyone has any solution or additional information for help, please let me know.
  1. Help
    7 vote(s)
    70.0%
  2. Help
    3 vote(s)
    30.0%
  1. Jul 5, 2019 at 1:27 PM
    #41
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Dealership will charge you 2 Techs 40 hrs each (flat rate). Although they do it in three days.
    GQ7227 likes this.
  2. Jul 5, 2019 at 1:34 PM
    #42
    GQ7227
    GQ7227 mw survivor
    J A Y
    :notsure:
  3. Jul 5, 2019 at 1:39 PM
    #43
    GQ7227
    GQ7227 mw survivor
    J A Y
    this makes sense with a couple of TW members repair order pics I have seen on here
    when do they have time to sleep during those 3 days?
  4. Jul 5, 2019 at 1:40 PM
    #44
    95v6mt
    95v6mt Well-Known Member
    scott
    maryland
    95 v6 mt extra cab
    Okay, I once read somewhere on the internet, so it has to be true.
    They traced the frame problem to the coating line at the frame factory. the frame was dipped in a coating ( paint but electrically charged ) that was supposed to be electrically attracted to and bond with the frame. Basicly the frame ran down a line that dipped into the coating, that part of the line was connected to the power supply to give a slight charge to frame. Well they found out the connection was loose, pretty much every frame that ran down the line had a faulty application of the coating. If its a sprayed coating its called electrostaticly applied, like powder coating, dont know exactly what its called when dipped.
    The coating stuck like a paint, but not like it was designed to do. This did two things, one the coating was not as "tight" to the metal as designed, two not as complete of a coating. Both of these allowed water/salt to get to the metal.
    better description with pics of the process ( not toyota )
    http://dearborndeuce32.com/32/index.php?main_page=page&id=3
    Hamer95USA and GQ7227 like this.
  5. Jul 5, 2019 at 1:43 PM
    #45
    robssol
    Rob
    S. Wisconsin
    They skipped washing the frames after machining and welding. Sent them straight into the rustproofing bath, contaminating it. Each frame made it worse and got less rust protection.
    Hamer95USA and GQ7227[QUOTED] like this.
  6. Jul 5, 2019 at 1:56 PM
    #46
    GQ7227
    GQ7227 mw survivor
    J A Y
    what year did this process start?
  7. Jul 5, 2019 at 2:03 PM
    #47
    robssol
    Rob
    S. Wisconsin
    Don’t really know but I would assume starting with the 2nd gens. But 1st gens had rust issues. But so did my 95 Ranger:rolleyes:(Ranger was worse than the Taco)
    GQ7227[QUOTED] likes this.
  8. Jul 5, 2019 at 2:38 PM
    #48
    TNToyo79
    TNToyo79 Just a Dude...
    Josh
    Georgia
    2019 SR5 2WD : 2016' 4 Runner
    5.29 Nitro Gear, JBA Offroad UCAs, Rough Country M1 Coilovers, Rear: Bilstein 5100's with 2.75"in. Blocks, 20" Fuel Assault on Atturo: Trail Blade XT's, Stereo that will make you go deaf.
    Started in 95'. The 95' - 00' models were bad. Those were the ones that Toyota took possession of and paid 150% of the value to the owners.
    05'-11' we're horrible too.
    I just got my 04' back from having the frame replaced. Just squeaked into that "within 15 years of first use" window..... and had all other qualifying factors as well.
    eimkeith likes this.
  9. Jul 5, 2019 at 2:41 PM
    #49
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have the actual #s model years and #s of those bot back and perhaps locations,etc.?
    or know where they are published?
  10. Jul 5, 2019 at 2:46 PM
    #50
    TNToyo79
    Josh
    Georgia
    No clue where to find that info. But that buyback deal was when it first started happening.
    eimkeith and GQ7227[QUOTED] like this.
  11. Jul 5, 2019 at 2:49 PM
    #51
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
  12. Jul 5, 2019 at 2:53 PM
    #52
    GQ7227
    GQ7227 mw survivor
    J A Y
    so far on TW i have seen huge majority of bad/questionable frames pics from 2oo1-2oo4, not so many from before this time period for comparisons
  13. Jul 5, 2019 at 8:11 PM
    #53
    Hunt/Taco
    Hunt/Taco Well-Known Member
    Coleman
    2003 Tacoma, Reg Cab, 2.7, 4wd, Auto. 90,xxx miles
    Pioneer Radio, New rear bumper (that does not really count though). Going to be upgrading it more and more as time goes on.
    Yes, I second what you just said. I had my 03 Tacoma frame replaced by Toyota (under recall last year), and they forgot to tighten up the transmission mount to the frame!! All 4 bolts where loose. Also they replaced the lower ball joints at the same time, as they had not been replaced under the lower ball joint recall. Well on one side, 1 out of the 4 bolts where gone!! Then the other side, lower ball joint, 2 out of the 4 bolts where gone also!! So one side had 2 bolts holding it, the other side had 3 bolts holding it. Like Toyota forget to put them in when they where replacing the frame. Either way, I am happy to have a brand new frame on mine!! Makes it tight again!!
  14. Jul 5, 2019 at 9:42 PM
    #54
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have more deets to support that in bold?
    all I have seen on TW are those 2oo1-2oo4 time period, the vast majority of them with posted pics anyways
  15. Jul 5, 2019 at 9:48 PM
    #55
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    My buddies 98 got bought back
    TNToyo79 and GQ7227[QUOTED] like this.
  16. Jul 5, 2019 at 10:41 PM
    #56
    GQ7227
    GQ7227 mw survivor
    J A Y
    and so did my relatives '98 in 2o11
    my '97 however checked out 0k so I am very curious about the frame re-design which occurred between the two model years that I have recently learned.
    Wondering what the change in materials or process might have been going on then and got really bad in early 2000s from the pics i have seen
  17. Jul 6, 2019 at 6:57 AM
    #57
    TNToyo79
    Josh
    Georgia
    I'm just going off all of the TW info out there. I've talked to a lot of people dating back to my first Taco when the coating bulletin came out...08' perhaps? I drove a 2000 pre-runner for 15 years, got scared when I got the bulletin, but I had lived in Cali most of those years and my frame was perfect. Still got coated though.
    This 04' just opened that can of worms again for me. I drove to NC to get it because the miles were so low 73K. I verified the frame was coated, but didn't do enough homework.
    A VIN search told the story.... It lived a long life in Vermont and Maryland. Under all that CPC coating, she had the cancer.
  18. Jul 6, 2019 at 11:54 AM
    #58
    GQ7227
    GQ7227 mw survivor
    J A Y
    I never got the bulletin in my location, had to hear it in late 2010 from a paltalk chatroom from a Tacoma guy in Indiana that told me about what was happening.
    took quite a bit of pleading with the dealer to get it checked, they never heard of it and didn't know how they were to be paid for checking! ... as far as i remember (its been over 8yrs now)
    my truck still feels like it basically only has 50k miles on it so mileage is a weird issue sometimes it all depends ... just throwing that # out there i have no clue :cool:
    i have YET to find much TW info regarding trucks pre 2000s, it's sporadic unless a deeper topic search is required
  19. Jul 6, 2019 at 1:40 PM
    #59
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    www.autorust.com
    Has all the frame patches. You can order and have your local body shop install.
  20. Jul 7, 2019 at 6:56 PM
    #60
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    my 03 replacement frame has the right rear spring hangers welded in the wrong location, causing a permanent crabbing of the rear axle (I'm having to move it to the correct location). I'm assuming Dana Corp made these frames as well?
    cruiserguy likes this.
