2002 Tacoma with 280,000 miles and big tires. Just got for my daughter.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ty5, Feb 19, 2024.
  1. Feb 21, 2024 at 7:31 AM
    #61
    Ty5
    Ty5 [OP] Well-Known Member
    Capt. Ty
    Cape Hatteras North Carolina
    Agreed
  2. Feb 21, 2024 at 7:34 AM
    #62
    Ty5
    Capt. Ty
    They are definitely hitting the frame, one spot looks like it’s beautifully polished silver
  3. Feb 21, 2024 at 7:37 AM
    #63
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    You'll want to buy this kit: 04005-03235 it is a kit Toyota made during the LBJ recall of both right and left LBJ and saves you about $100 over buying them independently.
    https://toyotaparts.ourismantoyotao...n-available-even-if-vin-is-supplied-400503235
    And the screws are Qty 8 of 90119-10933
    https://toyotaparts.ourismantoyotaofrichmond.com/oem-parts/toyota-bolt-w-washer-9011910933
    ~$190 for LBJs and ~$20 for bolts.
    Cloud99 and Ty5[QUOTED][OP] like this.
  4. Feb 21, 2024 at 7:39 AM
    #64
    Ty5
    Capt. Ty
    One more thing, it is on a 3 inch lift. Somebody was right they are round spacers. A the ball joint arms, etc. the same as originally usually or not?
  5. Feb 21, 2024 at 7:39 AM
    #65
    Ty5
    Capt. Ty
    Thank you for that, I’m heading to work, but I’ll be back later
  6. Feb 21, 2024 at 7:41 AM
    #66
    Ty5
    Capt. Ty
    Look at the last post I just did. It was a question about all the ball joints, are they the same as stock with that lif.
  7. Feb 21, 2024 at 7:45 AM
    #67
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Nice truck! Can I interest you in adopting an older child?
    Texasdynaryder likes this.
  8. Feb 21, 2024 at 7:58 AM
    #68
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Then you have wrong wheels for that... you get new wheel with some offset.. or you can get wheel spacers for each wheel.
  9. Feb 21, 2024 at 12:21 PM
    #69
    Ty5
    Capt. Ty
  10. Feb 21, 2024 at 12:22 PM
    #70
    Ty5
    Capt. Ty
    How about different size tires and if so, what would you do and size? The Rams are pretty nice.
  11. Feb 21, 2024 at 1:09 PM
    #71
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I would just downsize the tire if it were me. Wheel spacers are another option too. Only get Spidertrax or Bora brands. 1.25” spacers are typically the most common.
    Ty5[QUOTED][OP] likes this.
  12. Feb 21, 2024 at 1:10 PM
    #72
    TAZMINATOR
    2017 Tacoma
    I am still at stock size... I haven't upgraded the tires yet. When I do, I plan to get 285.
    What Rams are you talking about? If you talk about the pic above my username on the left pane, then it is not a Ram.. It's a Tacoma with aftermarket headlight.
    Or you meant your rims, then If you want to keep those, then you can either downsize the tire size to whatever you want or get wheel spacers.
    Up to you.
  13. Feb 21, 2024 at 4:18 PM
    #73
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    You have a body lift, that changes nothing on the suspension. Are you saying it also has a 3" suspension lift? Pictures of the front coilovers would help.
  14. Feb 21, 2024 at 5:06 PM
    #74
    Ty5
    Capt. Ty
  15. Feb 21, 2024 at 5:07 PM
    #75
    Ty5
    Capt. Ty
    I was talking about my rims which are 18 looks like I will just downsize the tires
  16. Feb 21, 2024 at 5:18 PM
    #76
    Ty5
    Capt. Ty
    I just took these photos in the dark, let me know if that’s what you were getting at? Thank you.
    3F107D1F-3E4B-4FB1-9078-72C2F8771870.jpg 893D5B87-6668-41C8-8567-4689042D340E.jpg
  17. Feb 21, 2024 at 5:36 PM
    #77
    Gen1andDone
    CV angles look like there is some kind of suspension lift. Stock shocks, could have a top load spacer or some type of lift coil. At least a 3" body lift too.
  18. Feb 21, 2024 at 6:05 PM
    #78
    Madjik_Man
    Colorado Front Range
    Im conservative admittedly.
    But those CV axle angles are pretty rough. The fine of the boots are almost all touching.
    And it probably has a spacer lift.
    The ride quality with that set up must be awful.
  19. Feb 21, 2024 at 6:30 PM
    #79
    Ty5
    Capt. Ty
    It’s a little rough riding but not that bad. And the tires are noisy. But it rides straight and no clicking noise from the steering while driving.. I did a quick test to move the tire up and down and it seemed tight but that was under load. Not jacked up. So obviously I’m green that’s why I’m on here. I’m just trying to figure out if I need to change the ball joints, tire size etc. I have no clue. All the spacing and rubbing on the lift kit is kind of beyond me
  20. Feb 21, 2024 at 6:33 PM
    #80
    Ty5
    Capt. Ty
    Isn’t photo number two approximately a 3 inch spacer lift?
