2002 tocoma extended cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trents Tocoma, Dec 6, 2023.
  1. Dec 6, 2023 at 7:51 PM
    Trents Tocoma
    Trents Tocoma [OP] Well-Known Member
    Trent
    2002 Toyota Tacoma extended cab
    Yea it’s a side to side wobble it happens on speed bumps and right and left turns.on speed bumps I go extremely slow going over them and it hits super hard.
  2. Dec 6, 2023 at 8:10 PM
    Michaelzg
    Michaelzg Well-Known Member
    Michael
    2002 Tacoma Flatbed
    Passenger side caliper may be stuck causing the truck to pull to the left when braking. Alignment should also probably be checked because of the lfit.
    Cooldaddy8 likes this.
  3. Dec 7, 2023 at 3:14 AM
    Trents Tocoma
    Trent
    I’ve got brand new calibers, brakes and rotors,brake hoses, all of that is brand new as far as alignment I’ve had 3 in the last month and it don’t fix anything
  4. Dec 7, 2023 at 3:58 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Have you ever replaced the lower control arm bushings?
  5. Dec 7, 2023 at 4:26 AM
    Trents Tocoma
    Trent
  6. Dec 7, 2023 at 4:57 AM
    Red_03Taco
    Jerad
    Did you use OEM Toyota bushings? I had a set of Moog ones fail in 3 weeks once
  7. Dec 7, 2023 at 5:09 AM
    Trents Tocoma
    Trent
    Yea they are moog
  8. Dec 7, 2023 at 8:25 AM
    Michaelzg
    Michael
    2002 Tacoma Flatbed
    Who did the work, could have been done wrong? I had that exact issue and found that one of the caliper pistons was seized.
  9. Dec 7, 2023 at 8:33 AM
    Trents Tocoma
    Trent
    I did it the 1st time then I actually took off the new calibers and replaced them again and took it to a shop the 2nd time
  10. Dec 7, 2023 at 8:55 AM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    What lift did you go with? You said 3" but not brand and type.
  11. Dec 7, 2023 at 8:58 AM
    Trents Tocoma
    Trent
    Bilstiens 5100 I did a add a leaf
  12. Dec 7, 2023 at 9:00 AM
    Dare Devil Diablo
    Dare Devil Diablo Well-Known Member
    2000 TRD Offroad MT
    Sounds like you have had considerable work done to this truck.
    I would go back and check every bolt where the suspension is bolted to the frame or the knuckle for propper torque.
  13. Dec 7, 2023 at 9:02 AM
    Gen1andDone
    So 5100's with original coils set to the top notch I guess, and an AAL in the original leaf packs. Is there any sound when this wobble happens
  14. Dec 7, 2023 at 9:20 AM
    Trents Tocoma
    Trent
    When you go over speed bumps there’s a big clunk in the front driver side
  15. Dec 7, 2023 at 9:28 AM
    #35
    Red_03Taco
    Jerad
    Have you attempted to recreate it with the truck on jacks?
    Have you ever inspected your front differential mount bushings? Mine got bad to the point that my diff was clunking against my skid plate up front (generally when going over bumps or stopping abruptly.
  16. Dec 7, 2023 at 9:36 AM
    #36
    Trents Tocoma
    Trent
    I haven’t checked that that will be something to look at as well.
  17. Dec 7, 2023 at 9:39 AM
    #37
    Trents Tocoma
    Trent
    My main thing that has me puzzled is the pulling left while breaking I’m writing down every idea everyone has it’s going to the shop tomorrow for the 5th time
  18. Dec 7, 2023 at 10:16 AM
    #38
    Red_03Taco
    Jerad
    To me it sounds like you have 2 unrelated issues:
    1) Front end clunk
    2) Pull to the left while braking.
    For #2 it's possible your rear end could actually be the culprit. Did you properly torque (and hopefully replace) your Ubolts when you lifted the rear? Have you checked your rear brakes out during any of this? I had a pull under braking after installing new rear drums and shoes and fixed it after a couple episodes of trial and error adjusting them.
    And for #1 you're gonna wanna check all the things mentioned earlier in this thread
    Ngneer likes this.
  19. Dec 7, 2023 at 10:30 AM
    #39
    Gen1andDone
    That's what mine did after installing 882's. Initially they gave over 3" lift which is too much, the shocks were topping out going over speed bumps. They quickly settled to under 3" and the top out clunk was gone. Probably not what you're experiencing and very well could be a loose or failed part. Some photos might help spot a problem. There are some knowledgeable folks on here with eagle eyes.
  20. Dec 7, 2023 at 10:33 AM
    #40
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    One more question - was all the suspension work (front and rear) done at the same time? One of the hazards of replacing a bunch of components simultaneously is when there are issues post installation, it's hard to pin down when so many parts are involved.
