2002 TRD 4x4 Tacoma suspension upgrade
Discussion in 'Suspension' started by Vectorit, Feb 12, 2010.
  1. Feb 12, 2010 at 10:11 PM
    Vectorit
    Vectorit [OP] Well-Known Member
    Southern California
    TRD SR5
    King coil overs, Total Chaos uppers, Snugtop
    I am new to this forum, so forgive me if this is a repetitive question for you all.
    Question I have is, that I plan to upgrade my stock suspension.
    I am very interested in the following package that has been set up for me by a local shop, and I am very tempted in pulling the trigger on going ahead with it all.
    My truck isn't driven everyday, and it only has 32k miles on the odo.
    Still has original TRD suspension, and even has the original BFG rugged trail tires. It's an extra cab, V6, 5-spd, auto lock front hub, and OEM locker rear.
    Currently, I am just unhappy with the suspension and tires. The tires are due for replacement, so I am just gonna replace everything at once.
    My off road style is desert exploration (none to little roads), mountain 4-wheeler trails, mostly dry dirt stuff with the rare mud/snow conditions.
    Highway driving to Vegas, and up to North CA to visit family about once a year.
    Just looking for opinions, good or bad I don't care.
    Total Chaos upper control arms
    Fox front shocks 0-3" coil-over set with remote reservoir
    Bilstein rear shocks
    Deaver rear spring additional spring packs
    4 Toyo all terrain 32/11.50 R16 tires mounted/balanced on OEM wheels
    Front diff drop brackets
    Urethane steering rack bushings
    Alignment
    Day's worth of labor/parts, for a total out the door cost of 4,100.00
    Comments?
  2. Feb 12, 2010 at 10:21 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    go with after market wheels that have 4-4.5'' backspacing so the tires will fit better, but thats a pretty sweet setup your looking at
  3. Feb 12, 2010 at 11:06 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    1st gen doesn't need the aftermarket UCAs so you could save some money there...
    the Fox coilover valving for the light body of a 1st gen is a lil firm...
    my vote,
    King coilovers - $975
    Deaver J59s - $600
    Custom 6" shackles - $125
    Bilstein 7100 10" short body shocks - $400
    $2,100 for your suspension parts, front and back...
    leaves you with enough money to get new wheels and tires...
  4. Feb 13, 2010 at 8:32 AM
    Vectorit
    Southern California
    TRD SR5
    Interesting. Thanks for the heads up on the UCA, and the difference between Fox and King. I did not realize that, and appreciate these type of comments!
    Keep em coming!
    Thanks
