2003 2.7 4WD Check Engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by giametta, Aug 28, 2011.
  1. Aug 28, 2011 at 6:32 PM
    giametta
    giametta [OP] New Member
    Marlboro,NY
    SR5
    Anyone have experience with check engine codes:pO441, PO442,P0446? Evap Emission leak/blocked,faulty purge,evap line leakage,pump module failure,faulty CCV vent control solenoid. What is the best way to begin to trouble shoot this? Any Advice appreciated. Thank you.
  2. Aug 28, 2011 at 7:05 PM
    dirtslngr
    dirtslngr Active Member
    sbonnoiv@gmail.com
    sbonnoiv@gmail.com
    i have the exact same codes, plus a cat converter code. faulty gas cap is the first place to look, and cheapest to try.
  3. Sep 4, 2011 at 10:28 AM
    wanoyee
    wanoyee Member
    I had the check engine light on and took it to a shop. They put it on a reader and then did a "smoke" test? Said it was some kind of evaporation canister or some sort... then was told that the part comes welded to another larger part and it costs $320 for the part plus labor.
    Later found out that a friend's son has a reader and when I put it on I got the same codes of PO441, PO442, and PO446.
    Does anyone have anymore info or experience they can share with these codes or parts mentioned?
  4. Sep 4, 2011 at 10:32 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
