2003 2.7L: Best performing spark plugs?
Discussion in '4 Cylinder' started by Backinblack03, Sep 19, 2012.
  1. Sep 19, 2012 at 5:41 PM
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS? What ABS?
    I've done some reading, and have yet to check what's actually in the truck at this point, but what do these little 2.7 motor like for plugs? Platinum? Copper? Iridium?
    E3's? (Just kidding!)
    Thanks!!!
  2. Sep 19, 2012 at 5:45 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    oem plugs work just fine.
  3. Sep 20, 2012 at 9:58 AM
    Backinblack03
    Brian
    VT
    ABS? What ABS?
    What flavor are the stock plugs?
  4. Sep 20, 2012 at 5:46 PM
    RideFast
    Jesse
    Tacoma
    It should say in the owners manual. The v6 takes denzos, not sure about the 4. Go to the dealer and get 4 plugs, You will spend less than $20.
  5. Sep 25, 2012 at 5:42 PM
    Backinblack03
    Brian
    VT
    ABS? What ABS?
    The dealer is practically on the other side of the world from me. Turns out stock were NGK V-powers? I found that to be weird. Anyway, I picked up a pack of NGK platinum plugs. Nothing fancy. The originals had worn the center electrode down to over .080" gap!
  6. Sep 26, 2012 at 8:59 AM
    LoneWanderer
    LoneWanderer Well-Known Member
    Randy
    Ohio
    03 4x4 Access Cab 2.7l 5spd
    Bilstein 5100s, Rancho Quick Lift struts, Wheelers 3 leaf aal, Procomp 8069s, General Grabber AT2 31x10.5, AFE Pro Dry S air filter, Dynomax Super Turbo muffler
    Mine had NGKs so I grabbed the oem version of those when I swapped mine recently. When I changed mine I almost crapped my pants. All four were pushing .090" gap they were that worn. I didnt know they were that bad, just figured it was time. My truck didn't skip a beat and I barely notice a difference with the new ones. Just shows how awesome these trucks are.
