2003 2wd Auto. A/C Squealing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sawiddy, Jul 31, 2011.
  1. Jul 31, 2011 at 12:05 PM
    Sawiddy
    Sawiddy [OP] New Member
    Cody
    03 Tacoma v6 2wd Auto
    I dont know if it's the pulley or the belt just being loose. The noise is only from the A/c being turned on. If the belt is loose how do I tighten it around the a/c.
  2. Jul 31, 2011 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Aug 5, 2011 at 8:16 AM
    pigger
    pigger Well-Known Member
    Greg
    Applecookie
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, older-than-dirt owner
    My '04 has been squealing badly whenever the AC compressor was engaged; yesterday I sprayed a boatload of silicone behind the pulley (between the pulley & the compressor) and it went away completely.
    Yay! I thought I might have to have the compressor clutch replaced.
