2003 3.4L TPS 4-Prong
Discussion in '1st Gen. Tacomas (1995-2004)' started by mcmanamus, May 3, 2017.
  1. May 6, 2017 at 12:24 AM
    #61
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Did you check all your fluids for water intrusion. Diffs and all? So no water got inside cab?
  2. May 6, 2017 at 12:25 AM
    #62
    mcmanamus
    mcmanamus [OP] Member
    2003 Tacoma Pre-Runner TRD
    None in the cab. Changed most of the fluids but haven't checked the diff, good call
  3. May 6, 2017 at 12:26 AM
    #63
    mechanicjon
    Jon
    Scottsdale Arizona
    Check it soon!
  4. May 11, 2017 at 1:29 AM
    #64
    mcmanamus
    Ok, so after a few victories and failures, it appears to be fixed. Prepare for a long post, and I'd like to preface it by saying I AM NOT A MECHANIC! But I'm a problem solver. And all the stuff I've done was up for regular maintenance anyway, so I didn't mind spending some money to change a lot of it out.
    So, since my last post, I've done some work. First, I got the whole used throttle body with sensors. I took the TPS off and slapped it on my truck. Little tip: angle you put the TPS on makes a HUGE difference. One way too far and the engine constantly revved itself up and down. Too far the other way and it just dies or goes into "limp" mode. So I found a good happy medium, hooked it up, and tested it out. No real change. Still stumbling, losing power, still throwing CEL. So, I decided to just throw the whole replacement throttle body on since I bought it anyway. That seemed to clean up the stumble and major power loss at low RPM. But I still had a hiccup and the CEL would blink when it was under load at high RPM, and the engine just didn't seem happy when I floored it. Decided to just buy a code reader already. Checked the code, P0303, misfire on cylinder 3. Well, if you remember, I replaced the plugs, so I figured it was one of 3 things:
    Plug Wires
    Injector Coil
    Fuel Injector
    I picked up some plug wires and an injector coil for the hell of it and headed home.
    Threw some sea foam in my tank and used the spray as directed... no change. Tried the multimeter on the fuel injector and number 3 was sitting at 16.7, well within range. Tried the "screwdriver test" and it sounded fine.
    Changed the plug wires. After a rookie mistake mixing up the wiring diagram, I eventually got it sorted out. Issue persisted.
    So... now for the ignition coil. Didn't think it would be it, since I've been told by multiple sources that if that was the problem it should be misfiring on 2 cylinders, since the coils run 2 cylinders. So I swapped the 1 and 3 coil and cleared my codes. Sure enough, went around the loop (that includes a nice little hill where it always throws the misfire code), threw the code, got home, read it, and got the P0301!! Swapped in the new ignition coil and that damn beauty of a truck is running better than I can remember. Test drove her for a bit, including hammering on the gas up a hill, and I swear she was so happy to be running smoothly I about did a wheelie in that thing.
    I definitely made some bone-headed rookie mistakes along the way, but I am a rookie after all and learned a lot from these forums, so thanks for all the good write-ups and input on here! Gotta drive up to a higher elevation on the island tomorrow so that will be a good test.
    Next fix is the tailgate latch. The threaded sleeves were spinning free in the handle, and won't come loose even after spraying some PB blaster on them... time to get out the grinder.
    jammer likes this.
  5. May 11, 2017 at 1:55 AM
    #65
    mechanicjon
    Jon
    Scottsdale Arizona
    Glad you got it fixed..:thumbsup:
    Being able to read and clear codes makes all the difference in the word. What kind did you buy?
  6. Oct 8, 2018 at 2:56 PM
    #66
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I know this is old but how did this all work?
    What did you do to the 4 prong airing harness to make it fit into the 3 prone throttle body?
    The pedal is deferent and it had a pedal sensor cable that is supposed to hook up to the throttle body. It wouldn’t be connected to anything if you swapped it out for an older throttle body.
    And what about the transmission kickdown cable? It’s all electronic on the 03-04 as well....
  7. Oct 10, 2018 at 9:32 AM
    #67
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I have 2, 4 wire throttle body's w tps if anyone needs them.
  8. Oct 10, 2018 at 10:18 AM
    #68
    Shortman5
    Supercharged TRD
    PM sent.
  9. Feb 25, 2020 at 9:58 PM
    #69
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
  10. Feb 25, 2020 at 10:13 PM
    #70
    mechanicjon
    Jon
    Scottsdale Arizona
    Yep thats it W0133-2744128
