2003 DCSB Tacoma 1 Ton SAS
Discussion in '1st Gen. Builds (1995-2004)' started by AggiePE, Feb 18, 2020.
  1. Mar 18, 2021 at 7:58 AM
    #61
    AggiePE
    AggiePE [OP] Well-Known Member
    Kelsey
    TX
    2003 Tacoma DCSB 4x4 & 83 FJ60 LS swap
    1 Ton SAS w/ 37's.
    a few more.
    Yota X, T.Barn, Wulf and 5 others like this.
  2. Mar 18, 2021 at 8:41 AM
    #62
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Looks good!!
    AggiePE[OP] likes this.
  3. Mar 18, 2021 at 11:57 AM
    #63
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  4. Jan 13, 2022 at 12:26 PM
    #64
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    Got the tire carrier and jack holder finished up and powder coated.
    T.Barn, Kkrause09, slander and 2 others like this.
  5. May 13, 2022 at 1:25 PM
    #65
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Wicked clean build man. One question, Professional Engineer, Petroleum Engineer, or both? Hahaha
  6. May 13, 2022 at 4:05 PM
    #66
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    Both, been a wild ride!
  7. May 13, 2022 at 7:15 PM
    #67
    TacoVio
    Kolton
    CO/WY
    That’s awesome man. I just graduated last May from the University of Wyoming. Petroleum Engineering as well. I’m out in Pecos right now workin MWD For a directional company. Hopin to get some field experience and land a Drilling Engineering job. Likin it so far! Well glad to meet a fellow PE on here :cheers:
  8. May 16, 2022 at 5:52 AM
    #68
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    Congrats on graduating! Likewise, don't run into many others. Hang in there, it'll be interesting to see what happens in the next 6 months with all of the supply chain issues...
  9. May 23, 2022 at 7:47 AM
    #69
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    Had a great time at the Toyota Jamboree at Barnwell! Met some great folks and ran some good trails! No breaks, but found a few clearance issues with my steering and brake lines. When the drives side tire stuffs, the spring would hit the Drag link and took out my grease fitting and would bind my steering. Got the solution working - next post. Saw how a guy used some springs and tubing clamps to get the brake lines out of the way, works well. Pitman Arm on Spring.jpg 14.jpg
    Broke Okie Ty and malburg114 like this.
  10. May 23, 2022 at 7:51 AM
    #70
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    I am going to go to a heim joint for the pitman arm end of my drag link. This will require me to build a pitman arm to get the center line of the drag link centered with my pitman arm. I had the parts laser cut locally and tig welded it together. I'm no expert tig welder, but by the time I was done the welds looked decent.
    Windigo and malburg114 like this.
  11. May 23, 2022 at 7:55 AM
    #71
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    I had to extend the drag link had to make up for the shorter heim joint vs the GM 1 ton drag link end. machined down a piece to act as an inner sleeve and plug welded the extension and welded around it, then cleaned it back up in the lathe.
    malburg114 likes this.
  12. May 24, 2022 at 6:39 AM
    #72
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    Notching the frame was not as bad as I had anticipated - had to do this to clear the castle nut on top of the pitman arm. As luck would have it, when I was threading in the Heim joint for assembly, the threads galled and I was unable to get it out. I ended up having to cut the old threaded bung off and start over with a new heim joint and threaded insert. Anyone have any suggestions on lubricants for the threads? never seize?
  13. May 24, 2022 at 10:49 AM
    #73
    slander
    Hickory, NC
  14. Jun 8, 2022 at 5:46 AM
    #74
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    Finished produce, used the never seize as mentioned in the post above. Worked out way better the 2nd time.. I gained a little over an inch of clearance from the spring, shake down run this weekend to make sure it all clears.
    I did a lot of looking and there are strong feelings for both castle nuts and cotter pins vs the all metal lock nuts. I went the all metal lock nut route for the 5/8" fine thread bolts for the heim joint. Anyone had issues with the lock nuts?
    Windigo, Broke Okie Ty and ToyRyd04 like this.
  15. Jun 8, 2022 at 7:58 AM
    #75
    slander
    Hickory, NC
    I would still look into a mechanical fastener. My steering box is setup similar to yours, and I was still able to get a castle nut on there and a cotter pin. You could also look into safety wire but that may be a PITA the first time you have to retorque that.
    I'm not too much of a safety dork outside of work (what I do for a living) but steering and brake systems I don't like to take many chances with.
    ToyRyd04 likes this.
  16. Jun 8, 2022 at 11:48 AM
    #76
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Any reason why you couldn't flip the 5/8s bolt (you'd need new, slightly longer one) and drill a hole below the nut for a cotter pin? Would help the safety factor 2 part, Upgrading and adding the cotter pin would prevent it from coming loose, but also if it ever did, the bolt should have almost no way of pushing up and out of the arm (nice design by the way).
    AggiePE[OP] and slander like this.
  17. Jun 8, 2022 at 1:22 PM
    #77
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
    The bolt is flipped for clearance. I actually took a bit off the bolt head with the lathe to thin it up a bit. It could possibly clear with the bolt facing down, but I'll flex it out this weekend to confirm. I agree the ideal situation would be for the bolt to go thorough the top.
    slander likes this.
  18. Jun 8, 2022 at 1:57 PM
    #78
    02hilux
    Planet: EARTH
    It's a late suggestion but why not run a 3/4" less than stock drop pitman arm vs a flat to prevent cutting the frame for clearance? Or run a nylon locking nut vs a prevailing lock nut like what you have? From experience, prevailing lock but tend to rattle loose unlike the nylon lock nut.
    I ran heim in the past at the steer box with double shear setup and haven't ran into the nut coming loose or disappearing with the nylon designed.
  19. Jun 8, 2022 at 4:28 PM
    #79
    slander
    Hickory, NC
    FWIW my castle nut hits my frame notch, and I made sure to keep the TRE hole facing parallel to the notch and let the castle nut self clearance.
  20. Jun 9, 2022 at 6:35 AM
    #80
    AggiePE
    Kelsey
    TX
    1 Ton SAS w/ 37's.
