2003 Regular Cab 4x4 Options
Discussion in 'Suspension' started by lucky73, Dec 5, 2012.
  1. lucky73
    lucky73 [OP] Limited
    Would like to know other RC owners experience, if you feel like sharing, on either of the following possible set-ups. Normal use will be no towing, very low weight in the bed if any at all, and Hwy/Light offroad and snow driving, 80-90% highway running.
    Option A:
    1.25" Lift and can run 275/70
    Front Bilstein 5100 (use stock springs) and Rear Bilstein 5100 at 1st setting +
    AARL @ progressive rate + top spacers (option) for more lift but no ride worsening.
    or
    Option B
    2.5" Lift can run 33" or 285/70
    Front ICON Coilover + ICON rear shock + AARL @ progressive rate
    Primary Goal is to improve ride quality and handling above all else and get some lift for larger tires. Likely to run 16" wheels.
