2003 Tacoma 4x4 muffler
Discussion in '1st Gen. Tacomas (1995-2004)' started by ugmold, Jun 3, 2010.
  1. Jun 3, 2010 at 7:02 AM
    ugmold
    ugmold [OP] Well-Known Member
    Well looks like a have a few holes in my original Tacoma muffler, not bad at 90,000. The tailpipe and headpipe look like they are pretty solid so I was thinking about cutting out the muffler with a sawzall and just replacing the muffler. I have had some interest in a "flow-thru" type of muffler.
    It looks like the original pipe is 2.25 inch, Autozone had a replacement that measured 2 inch. Does this mean the muffler should be male and pipes female? And would that work?
    Thanks,
    -ugmold
  2. Jun 4, 2010 at 10:11 AM
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
    If youre going to saw your muffler off and just clamp a new one on, I would suggest to make sure the new muffler has a 2.5 inch inlet pipe. I took the new muffler and made cuts on the inlet side, put copper silicone on it to seal it, and clamped it over the trucks exhaust pipe.
  3. Jun 4, 2010 at 10:13 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You can go with the 2" but get a reducer pipe as well. I personally went with a dynomax super turbo and it had the 2.5" inlet. Plus its pretty quiet.
  4. Jun 5, 2010 at 8:35 AM
    ugmold
    I think I'd rather go bigger or same size. Steve, where did you get your exhaust? Did it have the stock built in hangers?
    -ugmold
