2003 TACOMA DOUBLE CAB EXPEDITION/CAMPING RIG
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by travis.diller, Feb 25, 2015.
  1. Feb 25, 2015 at 2:10 PM
    travis.diller
    travis.diller [OP] Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    For Sale as built.
    Started its life as a 2003 DC Prerunner.
    I installed a factory E-Locker Rear axle and proceeded to convert it to 4wd.
    Front Differential is 4.10 geared non-add type, from a 4runner and uses manual hubs. Therefore, no electronic/vacuum actuators.
    The Transfer case is also from a 4runner and features the H type shift pattern making it purely mechanical, no motors or switches.
    The install is very clean and only recognized by Tacoma Aficionados due to the manual hubs and H pattern shifter. The manual hubs are factory Aisin.
    The Following list is installed equipment on the vehicle along with approximate price of parts.
    ARB bumper 866
    Warn Winch (USA model) 8k winch with synthetic line 650
    Aisin Manual Hubs
    Icon Shocks in front with 750lb springs and Camburg UCA 1800
    OME rear shocks 200
    Deaver 11 Pack leafs 1100
    BudBuilt full skids 575
    Gas tank skid 120
    Elocker skid 30
    BAMF sliders welded 400
    CBI rear bumper with dual can holder and tire swing out 1800
    Frame reinforcement plates 150
    Aluminum Shell With insert (tool boxes/storage/battery box) 2000
    Custom Baja rack and mount 1500 (including shovel/axe and high lift brackets)
    platform in place of rear seat to hold fridge/drawers (still have seat) 100
    ARB Compressor hard wired with hose fitting behind front bumper 300
    Rhino Rack 2m awning 300
    Dual Batteries, Yellowtop 34 as starting, yellow top 31 as house 300
    Blue Sea Automatic Charging Relay/ switch 260
    Blue Sea Fuse Panel 40
    Edgestar FP430 Refer. 300
    265/75r16 Toyo Open Country M/T x5 with lots of life left 800
    CB radio installed in place of ashtray. 70
    ProClip Center Dash Mount 30
    Panavise In Dash Mount to hold Tablet etc... 30
    Paranoid Fabrication Six Switch Plate 30
    The truck has been meticulously maintained and recently had its second timing belt change ahead of schedule.
    Runs on synthetic oil since I have owned it.
    Only one small dent (mall-crawlers) under the rear tail light.
    Has some desert pin striping most of it should buff out, I never really tried.
    $23000 or make an offer
    Price Includes all options listed. Totalling over $13,500 in modifications not including labor.
    157*** miles.
    Please Text me for Specific pictures of anything you want to see.
    8054two39278
    IMG_20141107_152358_zps25b96bca_bafa4197e8becdf03fc6ce742f891b8ee8e148bd.jpg[​IMG]IMG_0416_zps70f77fa7_03ed7795cae44c84d9ff0cf18a84daf67ed4705c.jpgE69A2BA0-277A-4748-BBA4-DBD24C697BAE_zps_1b1716e6256c1925138e413273e93b995634c63d.jpg4F5BC141-3573-4CBD-8647-D95B894C1D13_zps_c640d9a64b2f4f7a2b048305c935f132cf742d4e.jpg[​IMG][​IMG]F4D9D906-B3A8-443C-88B4-0C1A7D052A90_zps_99b7c5c8f22ae1556b633af8266992a630cb2d8e.jpg[​IMG]467E5541-E46E-4DAC-925A-210E55F575A2_zps_f49005235b0cf18b0fdd76e37fc34f8ca653dd9e.jpg7DD4545F-1336-406E-9FC9-68E8AD96EFEA_zps_53ff019e083918e36c827950eaf14f61fae1c457.jpg[​IMG][​IMG]45BFF99E-3A29-4A68-A964-5262E836BE18_zps_7faa60de8fb88c5e7869105f32e0c95e3220c2af.jpgBE6B9ADB-2986-465B-AD78-3B10DAF2EEF6_zps_d58277ce5d887c052cdd8029b5eb9c32ab1d5973.jpg08A86820-83FB-4A40-8B4D-D301EBA88B09_zps_68b31447c1a510f914f06c740135feb18894b28f.jpg
    SSG (03)TACOMA and TWENTYCO like this.
  2. Feb 25, 2015 at 6:50 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Awesome truck man, glws
  3. Feb 25, 2015 at 8:22 PM
    travis.diller
    Travis
    Kitsap Peninsula
    thanks, hoping someone makes an offer, I am anxious to start another build... (A.D.D.)
  4. Feb 25, 2015 at 10:21 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    2F23+34 Lake George, Colorado
    15 TRD Blown OffRoad
    TRD Supercharger
    That's a great ARE shell. I love mine, even though it doesn't match the body lines and the paint on top is all faded. It can handle 800lbs mounted directly to it due to the welded aluminum internal framing. Also, the side doors are awesome for access.
    [​IMG]Untitled by jasonleeferrier, on Flickr
    [​IMG]Camp: Morning Three by jasonleeferrier, on Flickr
  5. Feb 26, 2015 at 8:25 AM
    monyman
    monyman Well-Known Member
    Central CA
    Very nicely done expedition mods! GLWS.
  6. Mar 1, 2015 at 11:59 AM
    travis.diller
    Travis
    Kitsap Peninsula
    make me an offer I can't refuse!
  7. Oct 28, 2016 at 11:30 PM
    tmger
    tmger New Member
    Hi, I was wondering what you made the platform in the rear seat out of? I'm wanting to mount a small job box.
  8. Oct 29, 2016 at 7:26 AM
    FJZooga
    FJZooga Well-Known Member
    Rob
    Sonoma County Ca.
    FJ40
    what was your reason for using an IFS when you could have use a solid axle?
  9. Mar 23, 2019 at 9:48 PM
    CodyDaltonNV
    CodyDaltonNV Well-Known Member
    03 DC Tacoma
    What were u using to hold your Harmon I reach with
  10. May 27, 2019 at 3:16 PM
    powderhounds
    powderhounds Member
    garrett
    Where are located?
  11. May 28, 2019 at 11:03 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    This thread is 4 years old...
  12. May 29, 2019 at 1:18 AM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Commiefornistan
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Is it therefore irrelevant?
  13. May 29, 2019 at 3:27 AM
    BeLance89
    Brandon
    Huntsville, AL
    Yes. Yes it is.
  14. May 29, 2019 at 3:34 AM
    BeLance89
    Brandon
    Huntsville, AL
    I’ll answer the questions, or try to anyways. He’s located in the Kitsap Peninsula. As for the Garmin InReach, judging by where it’s mounted (in front for the vent), it’s probably on a vent mount. Lots of vent mounts are magnetic now and would be a good fit for that size Garmin. Really am trying to be helpful on that and not sound sarcastic.
