2003 tacoma is shaking at 60mph+
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mlong17470, May 16, 2023.
  1. May 18, 2023 at 1:01 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I had vibration that started around 55 and stopped at 70. I had a slight crack in one of the ujoints.
  2. May 18, 2023 at 1:11 PM
    Mlong17470
    Mlong17470 [OP] Member
    2003 tacoma trd off road 3.4 manual
    Was it a nasty vibration?
  3. May 18, 2023 at 1:11 PM
    Mlong17470
    Were you able to visually see the crack?
  4. May 18, 2023 at 1:19 PM
    JPinFL
    At first, no. But after a few days, it got worse.
    I only noticed it because the ujoint was positioned where the crack was facing straight down. If it were facing the side, probably not. Also, I had just wiped it clean so that I could grease them.
  5. May 28, 2023 at 8:29 AM
    dirty_lickings
    dirty_lickings Active Member
    JB
    Upcountry Maui, Hawaii
    02 3.4L V6 PreRunner Dbl Cab
    •New paint •Removed running boards & DRLs •Tinted windows •Trac-Rac installed •Custom Wet Okoles front & back seats •Alcoa chrome rims •Alpine stereo receiver/bass knob/5x7speakers/amplifier/ 2-8”subwoofer boxes •3” Lift Kit •Bilstein shocks & struts •Spidertrax wheel spacers •Smoked lights all around
    Tie rods. Check your inners.
  6. May 28, 2023 at 2:24 PM
    zrodwyo
    zrodwyo Well-Known Member
    Wyoming
    2001 Xtracab TRD
    My bad vibration was caused by a bad brake master cylinder that was causing my brakes to lock up.
  7. May 28, 2023 at 2:32 PM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Mine was tire balance. I ran 2nd gen 17" wheels for a while and even had an argument with a stealership service manager about it. Has anyone ever told you about lug centric vs hub centric balancing?
    I run 1st gen 16" steelies now that are much more forgiving to the tire shop folks.
  8. May 28, 2023 at 2:43 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Normal wheel balance issues present their ugly head around 60 MPH.
  9. May 31, 2023 at 11:23 AM
    Mlong17470
    Check for play when jacked up?
  10. May 31, 2023 at 11:24 AM
    Mlong17470
    I am noticing inside of tire on one side is wearing much faster than other side.
  11. May 31, 2023 at 11:24 AM
    Mlong17470
    Fairly new lower ball joints and tie rods both sides
  12. May 31, 2023 at 2:23 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    No such a thing as a "slight" crack in a U joint!
