2003 tacoma old emu/5100's experiences
Discussion in '1st Gen. Tacomas (1995-2004)' started by camt10, Apr 24, 2013.
  1. Apr 24, 2013 at 2:35 PM
    camt10
    camt10 [OP] Well-Known Member
    03 ext cab sr5 trd 4x4
    I would like to hear from people who ran both lift setups
    Option1. Adj5100's up front with eiabach coils and rear dakars
    Option2 old man emu full kitt 881s nitro charger shocks all around and rear dakars.
    Truck is daily driver,also going to put a heavy arb or similar bumper so unsure if I go with old man setup will I get less lift once installed,wher I could always adj 5100's to compensate. And yes searched quite a bit.
  2. Apr 25, 2013 at 4:40 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I mixed OME coils and 5100s
  3. Apr 25, 2013 at 4:45 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Just get a stiffer OME spring. I ran the nitro charger in the front on my last 4runner and they held my arb just fine. I ordered them for my runner I have not too. It's a good set up. I also ran 5100's at 1.75 and eibach springs in the front on my 07 Tacoma and liked it as well.
  4. Apr 25, 2013 at 6:09 PM
    camt10
    Just wondering if old man setup is worth the extra coin if th 5100's r good
  5. Apr 25, 2013 at 6:23 PM
    Hoyal
    Devin
    2013 Tundra
    It's really up to you. I'm in the process of a new build and I did for the fronts. But I'm doing OME springs in the rear with billy 5125's for the shock, and OME Front shocks and sprigs. But I have a runner so it's a different lift.
  6. Apr 25, 2013 at 7:41 PM
    hec983
    hec983 Well-Known Member
    X2
  7. Apr 26, 2013 at 12:43 AM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BEL Pro500; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x3, and I remain very happy with the combo.
    Using 5100s to pre-load your springs will provide a somewhat harsher ride than replacing the springs themselves. You'll also want to do your homework before pre-loading OME coils. (While it can be done, it's not generally recommended.)
  8. Apr 26, 2013 at 3:53 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    if you are going to put a heavy bumper up front. dothe OME 882 with OME shocks. 5100 are not made for weight lifting. I have the OME setup with the added weight of almost 200#s with bumper and winch. no issues to date. very happy with the setup.
  9. Apr 26, 2013 at 9:21 AM
    camt10
    Talked to arb tech finally decided,arb bumper,full OME Isuspension,THEY REC 881 AND DAKAR COMPLETE LEAFS 881 because no winch
  10. Apr 26, 2013 at 2:32 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    881s with an ARB style bumper will essentially give you stock ride height in the front after they settle. If you are putting up the extra weight of a plate bumper the 882s are the way to go.
    The 881s+plate bumper and some Dakars will give you a serious rake. Even the 881s with stock bumper and Dakar leafs will be a pretty big rake.
    There are also tons of people on here running 5100s with ome without issue.
  11. Apr 26, 2013 at 5:03 PM
    camt10
    Dunno guy at arb said I would be left with a 2 inch info after arbinstall
  12. Apr 26, 2013 at 5:11 PM
    Hoyal
    Devin
    2013 Tundra
    I had the stiff OME coils, Nitrocharger shocks a heavy ass arb and a smitty built winch on my last 2000 runner and it had 34 inch tires on it. It held the bumper fine, but it sounds like you already made your mind up so Ill stop trying to sway ya. Good luck.
  13. Apr 26, 2013 at 5:30 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Maybe on the first day with a stock bumper. They are only rated for a 1.75-2" to begin with. After settling and an extra few pounds of plate bumper they you be left with much lift.
  14. Apr 26, 2013 at 7:08 PM
    camt10
    I just don't want to over do it with a over rated coil pound rating that is
  15. Apr 26, 2013 at 8:53 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I used to run stock coils with the 5100's set at 2.5" of lift. With this setup I thought the ride was very nice. Now with ome 881 and nitrocharger shocks the ride is very stiff. Also FYI I got 2.5" of lift with the 881 coils.
