2003 Toyota Tacoma V6 hesitation
Discussion in 'Toyota Trucks & SUVs' started by Eriksen0108, Jul 1, 2012.
  1. Nov 9, 2012 at 3:51 PM
    #121
    Markmmg
    Markmmg Well-Known Member
    Mark
    Baton Rouge, LA
    Prerunner double cab
  2. Nov 9, 2012 at 6:57 PM
    #122
    Markmmg
    Mark
    Baton Rouge, LA
  3. Nov 9, 2012 at 10:07 PM
    #123
    bseant
    bseant Active Member
    central valley,cali
    04 doub cab prerunner
    cool thanks man. Was the installation a pain or did it go relatively smooth?
  4. Nov 10, 2012 at 5:06 AM
    #124
    Markmmg
    Mark
    Baton Rouge, LA
  5. Nov 17, 2012 at 8:37 PM
    #125
    joes06tacoma
    Joe
    Central Coast, CA
    How old is the timing belt? Could it be a tensioner issue? Just thinking out loud here.
    On older vehicles I have had, this has been plug wires, bad vacuum advance module/distributor, fuel pump......stuff you don't have or have eliminated. But the same principles apply. Bad spark timing, valve timing, or a lean condition would cause it. But I would expect you to have a fault code stored too.
    Have you checked the compression? How does it idle? Never heard of a 3.4 having valve clearance issues at less than 150K, but it could happen.
    Edit: Just thought of this. My boss had a 98 4Runner with 3.4 and it had a fuel injector go bad. I don't remember the exact symptoms he had, but it took awhile to track that down. Not sure how the mechanic finally figured it out.
  6. Nov 21, 2012 at 7:28 AM
    #126
    Markmmg
    Mark
    Baton Rouge, LA
  7. Nov 22, 2012 at 12:54 PM
    #127
    Tenax
    Tenax Well-Known Member
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    Got mine today. Looks good, mark!
  8. Nov 23, 2012 at 12:55 PM
    #128
    Markmmg
    Mark
    Baton Rouge, LA
  9. Nov 27, 2012 at 8:25 PM
    #129
    will33
    will33 Member
    will
    colorado
    k&n cold air intake, g-force computer chip, 2.5 " rough country lift, rancho 9000 series shocks, front custom bumper, rear rock crawler bumpers, piaa 3" fog lights
    ok. First of all I have an 03 trd that I bought in 05 with 37000 miles. i have the same truck and have been up with all services including synthetic oil and diff fluid. I now have 123000 thousand on it. I have to say, I have never had this perplexing issue luckily. One year ago i bought a g-force computer chip which reprograms the trucks computer to make it more efficient and to correct some of the issues that occur within the program of the vehicle. It might be a worthwhile investment. Its only $80 and it has slightly improved fuel economy, and has made the idle alone noticeably smoother. I do think the problem is in the programing software and not the mechanical workings of the vehicle. Just note, they do say that it takes 100 miles to reprogram the trucks computer. I had a lag in the idle at about 25 miles so bear with it, and as I did, I think you might find some relief. Would be anxious to hear some results.
  10. Dec 10, 2012 at 10:46 PM
    #130
    Redd
    Redd Member
    I just registered to chime in about this problem since it seems like an issue a lot of Toyota owners have been frustrated with. I got my Tacoma (97 manual trans 5vz-fe) a year ago which was running great for a couple months but then developed the intermittent stumbling/hesitation problem everyone in here has described. I replaced the plugs, wires and all 3 coilpacks with no success.
    After that didn't fix the stumble my next guess was a sensor since the truck ran great except for this narrow spot it would intermittently stumble on lighter acceleration (often at cruising speed). Roughly the last couple of weeks though the truck has been almost undrivable due to it stumbling constantly when at cruising speed. After reading this thread (and a few others) the tps seemed like the most likely culprit. I just got the new tps today and since the install it has not stumbled at all. Just wanted to let everyone know this fixed my issue as well. I think it is safe to say if you develop the strange intermittent stumble/hesitation during lighter acceleration but your truck otherwise runs good the tps sensor is probably worn out and failing.
    swellcat likes this.
  11. Apr 24, 2013 at 7:41 AM
    #131
    Markmmg
    Mark
    Baton Rouge, LA
  12. Apr 24, 2013 at 2:53 PM
    #132
    FramerKat
    FramerKat Well-Known Member
    kAt
    Fort Lauderdale, Florida
    2004 PreRunner TRD Limited DC
    Wheeler's five pack leaf springs, Bilstein 5100s (rear), front tint, windshield top tint, Century Camper Shell/Cap/Topper, Wade window visors, Wade bug shield, cassette adaptor (so I can play Slacker Radio via my phone!), Sunday Blues with Dar sticker, Wounded Warrior Project sticker, no NRA sticker 'cause I don't wanna advertise ;-)
    It's funny...I've been thinking about this problem recently...my truck hasn't done it since our "rainy season" ended last year. I have driven through a couple of fairly large puddles though...and it still hasn't happened (it had previously after I drove through a fairly large puddle). We'll see what happens when the real rainy season starts again...which should be in the next month or so.
  13. May 4, 2013 at 5:44 PM
    #133
    budshupe
    budshupe Member
    bud
    lakeside ca
    03 Tacoma trd
    I don't see them. maybe they're already gone. Are you going to get more?
  14. May 5, 2013 at 5:15 AM
    #134
    Markmmg
    Mark
    Baton Rouge, LA
  15. May 5, 2013 at 7:25 AM
    #135
    budshupe
    budshupe Member
    bud
    lakeside ca
    03 Tacoma trd
    has anyone opened up one of these sensors to see whats going on or if they could be repaired. Does anyone have a drawing or exploded view?
  16. May 6, 2013 at 3:22 PM
    #136
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I have one from the first batch that I bought from Markmmg still unopened. PM me if you want it.
  17. May 8, 2013 at 5:58 PM
    #137
    budshupe
    budshupe Member
    bud
    lakeside ca
    03 Tacoma trd
    I sent you a PM.
  18. May 9, 2013 at 12:22 PM
    #138
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Sold
  19. Jun 24, 2013 at 12:02 PM
    #139
    tubbsj
    tubbsj New Member
    Johnny
    Alabama
    2003 Toyota Tacoma
    Do you have any TPS (89452-35030)?
  20. Jul 19, 2013 at 11:54 AM
    #140
    Tyree
    Tyree Member
    Washington State
    2003 Tacoma 4x4
    I just ordered five Tacoma TPS sensors part #89452-35030 from on overseas wholesale supplier. They should be here in five days or so. Let me know if you are still interested.
    Ty
