2003 Toyota Tacoma V6 hesitation
Discussion in 'Toyota Trucks & SUVs' started by Eriksen0108, Jul 1, 2012.
  1. Nov 25, 2013 at 11:10 PM
    #161
    smooth60
    smooth60 Member
    newport nc
    02 prerunner
    Thanks Kevin I'll visit auto zone today. Let you know tomorrow
  2. Nov 29, 2013 at 5:30 AM
    #162
    smooth60
    smooth60 Member
    newport nc
    02 prerunner
    Hi Kevin problem still not solved-crazyyyy
  3. Dec 1, 2013 at 1:55 PM
    #163
    smooth60
    smooth60 Member
    newport nc
    02 prerunner
    Hi Kevin no success still reading po302 po305 3 garages 285.00 spent parts 1 coil truck now runs very bad in damp weather but idles great had to depress accelerator pedal very hard to move truck back in yard. Felt like brake was on ...truck very unsafe to drive...appreciate your help
  4. Dec 20, 2013 at 7:24 AM
    #164
    Ferbedo
    Ferbedo New Member
    I have the same problem, tacoma 2000 4x4 2.7 engine, no I check the temperature sensor?
    I verify that when the engine is cold, this problem does not occur, then when the temperature rises the problem starts
  5. Dec 21, 2013 at 7:30 PM
    #165
    budshupe
    budshupe Member
    bud
    lakeside ca
    03 Tacoma trd
    Why don't you guy's "TEST", instead of just "GUESS". I had the same problem with my '03 3.4L Tacoma. After gaining some insight and good clues( thanks to the forum) I tested my throttle posistion sensor. A simple procedure outlined in the Haynes manual. And "GUESS " what , my TPS was defective !! Imagine that ! Finding the right new one was a trick though. Thanks again for the forum. 10,000 miles ago and no problem since.
    Offroad2 likes this.
  6. Jan 23, 2014 at 11:22 AM
    #166
    jaycob
    jaycob New Member
    tps is probably the most likely. If this doesn't work has anyone checked for vacuum leaks?
  7. Feb 12, 2014 at 2:49 PM
    #167
    DrCaptnPhD
    DrCaptnPhD Member
    CT
    12 Tacoma TX Baja
    Baja Package, 295/75R16's on TRD beadlocks, 3" performance accessories body lift, 3" pro comp suspension lift, TRD CAI, TRD supercharger, black leather Katzkin heated seats, extang tonneau cover, pillar pod w/ boost and AFR gauge.
    I had this problem on my 01 tacoma. new coils, High octane fuel, proper plugs, properly gapped and injector cleaner.
    Problem solved
  8. Oct 5, 2014 at 4:49 PM
    #168
    squrrrlygurl
    squrrrlygurl Member
    Oakland, CA
    2003 4x4 SR5 DeChromed
    Debadged, Black Trim
  9. Aug 3, 2017 at 11:04 PM
    #169
    Koad
    Koad New Member
    Kekoa
    Toy
    None
    Has anyone try this website to find the throttle positioning sensor 89452-35030
    Xiuyansensor.com?its either them or alibaba.com.
