2004 2x4 tire sizes - p205-75-15
Discussion in '1st Gen. Tacomas (1995-2004)' started by j74brown, Jun 25, 2010.
  1. Jun 25, 2010 at 1:11 PM
    j74brown
    j74brown [OP] New Member
    Orlando
    2004 Tacoma 2x4
    none
    I am sure this has been asked a ton of times, however I cant seem to find the answer. I just bought a 2004 tacoma 2x4 and am wondering what the largest size tire I can put on it with stock suspension. Currently it has p205-75-15, I would like to stay with a 15" rim.
    Any Help?!
  2. Jun 25, 2010 at 5:10 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    a 2x4 is piece of lumber
  3. Jun 25, 2010 at 9:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    How many lug nuts do your wheels have? Do you have 5 lug nuts per wheel?
  4. Jun 25, 2010 at 11:25 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    If your truck is a 2.4L then 215/75R15 is max!
  5. Jun 28, 2010 at 8:30 AM
    j74brown
    Orlando
    2004 Tacoma 2x4
    none
    Thanks so much - thats what I need to know!
