2004 Blowing Steam From Tailpipe After Rain
Discussion in '1st Gen. Tacomas (1995-2004)' started by chomachomachoma, Aug 27, 2019.
  1. Sep 4, 2019 at 4:41 PM
    chomachomachoma
    chomachomachoma [OP] Member
    Columbus, OH
    0H-4 Taco Rescue
    Restoring to all OEM
    If it were a head gasket, why does this only happens after it sits in heavy rain? Wouldn't it also do it in dry conditions too if it was a head?
  2. Sep 4, 2019 at 5:03 PM
    Indy
    Indy Master of all I survey.
    Does it start immediately after startup? It takes a while for exhaust to get hot enough to boil off water. If you start steaming immediately after startup, it's not the exhaust.
  3. Sep 4, 2019 at 6:28 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I should think so. Still don’t think it’s water in the exhaust causing steam, it has to be caused by getting water into one or more cylinders since it steams immediately on starting. If water in the cylinder(s) isn’t coming from the coolant then that leaves what, the air intake? I could see how that would play up with the symptoms. Heavy rain infiltrates the air intake and pools up somewhere and gets sucked into cylinders and makes steam until the pool is depleted. Have you checked the air box after a rain?
  4. Sep 6, 2019 at 7:50 AM
    chomachomachoma
    Columbus, OH
    0H-4 Taco Rescue
    Yes. It starts up fine. It takes about 10 to 20 seconds before the steam starts up. Starts slow, then gets worse as the engine heats up.
  5. Sep 6, 2019 at 7:52 AM
    chomachomachoma
    Columbus, OH
    0H-4 Taco Rescue
    Airbox was replaced with cold air intake. I don't see any water getting near it. But could be worth a shot to remove the filter anyway next time it rains to rule it out.
  6. Sep 6, 2019 at 8:02 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    That's an issue, I bet it's sucking water through that CAI .. there's lots of posts on here of people having more water problems in the rain after they install one of those, you'd be surprised how much water can enter the engine bay from underneath when you drive in the rain.
    Do you still have the rubber inside fender protectors?
  7. Sep 6, 2019 at 8:10 AM
    chomachomachoma
    Columbus, OH
    0H-4 Taco Rescue
    Not driving. The truck sits in the driveway. It rains on the truck (truck is motionless), then problem occurs only on first startup after rain.
  8. Sep 7, 2019 at 6:31 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    You said you have leaking welds from new exhaust installation, are these welds anywhere where rain water running off the cab or box could be dripping on them and getting inside the exhaust? Looks 100% like it’s rainwater getting inside the exhaust to me. Doubt it’s from the air box as that means it is entering the combustion chamber and going through the FI, it would be running like crap with any amount of water there.
    Maybe there is an exhaust fitting where the female pipe fitting into the male pipe is “upside down”, ie. so water hitting the pipe runs down into the exhaust and pools somewhere until you heat it up when you start it up?
