2004 Component Speaker Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by rrosebr, Sep 28, 2010.
  1. Sep 28, 2010 at 11:09 AM
    rrosebr
    rrosebr [OP] Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    I want to do a new audio system in my 2004 Tacoma Double Cab. I really want to use component speakers but want to keep the stock look. Is it possible to put new tweeters behind the stock grill? Thanks for the help!
  2. Sep 28, 2010 at 1:20 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I have seen tweeters installed that don't use the stock grill. http://www.customtacos.com/forum/showpost.php?p=726224&postcount=13 , but I can't remember seeing any aftermarket tweeters using the stock grill (not that it can't or hasn't been done). The stock grill is pretty shallow. Maybe you could get some inverted dome tweeters in there?
    I personally don't like to have the tweeter separated from the mid/woof that far. Of course the trade-off is sending the highs into your leg. Some coax speakers do have an adjustable tweeter that you can angle up for less high frequency roll-off if you go that route.
  3. Sep 28, 2010 at 5:01 PM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    I put in Alpine SPR17s components. The 1" tweets fit fine in the stock location. The 6" woofers had to be put in the back door due to the depth. I Had to make baffles out of 1/2" MDF also had to do some minor trimming on the door panels. In the front doors I left the factory speakers. After some tunning I am very pleased how it sounds.
  4. Sep 29, 2010 at 8:41 PM
    adhumston
    adhumston Well-Known Member
    Most tweeters will actually fit behind the stock grill. You may have to do a little fabbing to figure out how to mount them, but they'll generally fit (w/o the aftermarket grill still attatched). Another option is to paint the grill on the aftermarket tweets to match. Most people would never even notice.
  5. Sep 30, 2010 at 2:32 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    ive got a second gen tacoma and i was able to mount my tweeters behind the stock grill. just had to alter the original tweeter brackets some
  6. Sep 30, 2010 at 5:50 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I installed some Alpine Components in my 01 Extra Cab this past weekend. The only issue we ran into was speaker depth on the 6.5s. We used 3/4 plywood to make a new mounting bracket and then used the plastic speaker mounting kit that came w/the speakers. It cleared inside the door but gave us problems with the door panel. We trimmed a few areas on the panel and still had issues. We ended ordering some replacements online that fit 6.5s. I think if we used some 1/2 wood we might have been in the clear.
    The tweeters fit fine in the stock location. I used strap tape to hold them in place. (I got it in the plumbing area at Lowes. looks like https://www.plumbersstock.com/images/products/large/00291269.jpg )
  7. Sep 30, 2010 at 9:20 AM
    scocar
    scocar Treat the cause, not the symptom
    Ricardo
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Which Alpines did you get? I am starting to reseach new components, and wanted to try 6.5s. I listened to some at Best Buy, and they were great. I think it was the SPS-600C
    http://www.bestbuy.com/site/Alpine+...stem/8699438.p?id=1199494646675&skuId=8699438
    Also, were you able to retain the stock grills on both the tweeters and the woofers?
  8. Sep 30, 2010 at 12:12 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    I think they are these:
    http://www.crutchfield.com/S-JI9F7xnaBGN/p_500SPS171A/Alpine-Type-S-SPS171A.html
    I got them from a friend that had them in the original box for a few years. He tossed the box when he brought them over. Everything looks stock. All grills are in place. I also used the stock head unit and it sounds fine.
  9. Oct 3, 2011 at 10:21 PM
    MountainMike
    MountainMike Well-Known Member
    Kentucky
    '99 Tacoma
    I know this thread is old, but this is exactly what I am trying to do. Can you post pics of your install?
  10. Oct 3, 2011 at 10:34 PM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    i know bostons tweeters are pretty small, u could probably fab up somethin small to hold it in place behind the grill so u dont have to use the provided bracket
  11. Oct 5, 2011 at 7:38 AM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    I put a set of Kenwood components in the stock locations, it wasnt that bad.
    I used the existing brackets with just 1 screw on the speakers, and they fit pretty well, the grills have a little angle to them, they are not perfectly flush, but nobody notices.
    The box is double sided taped to the door panel, and I did put a QD to disconnect them when I pull the door panels off.
    I also put a Kenwood SW1 under the seat, it works well.
    K.L.
  12. Oct 5, 2011 at 8:01 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Yes, it is possible to use the stock grill, I have done it. It just depends on which tweeters (how deep they are).
