2004 tacoma - cabin heater fan sounds "plugged"
Discussion in '1st Gen. Tacomas (1995-2004)' started by HikerLT, Aug 14, 2011.
  1. Aug 14, 2011 at 8:32 AM
    HikerLT
    HikerLT [OP] New Member
    2004 tacoma 4x4
    When I turn on my cabin heater fan, it sounds like the air flow is restricted or plugged - and small dust and crap comes out of the vents on the dash, etc....sounds gets more restricted sounding as I turn the fan on high, where it's actually rather loud, like a lud low hum....the air is coming out, but not freely.
    I was able to remove the glove compartment, but need advice, pointers to a manual, or other hints what I should be looking for
    Any help appreciated !
  2. Aug 14, 2011 at 10:52 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    Here is a link to the blower motor removal in the fsm. You can look through that and see that removing the blower motor is very easy. I took mine out and cleaned the squirrel cage. You can also get to some duct work at that time to clean it.
    http://ncttora.com/fsm/2003/Repair_Manual/03tacoma/ac/blomot/insp.pdf
    This is a link to the complete fsm for your reference. Just scroll down to you model and you can down load the fsm.
    http://ncttora.com/fsm/index.html
    Do you hear your mode doors moving when you change from dash to floor and such?
