2004 Tacoma Double Cab Dash Problems
Discussion in 'Technical Chat' started by Explodoboy, Oct 5, 2009.
  1. Oct 5, 2009 at 1:41 PM
    Explodoboy
    Explodoboy [OP] New Member
    Christopher
    Rayne, Louisiana
    2004 Prerunner SR5 double cab
    My Fuel Door indicator does not go off when I turn on the headlights. My Low fuel indicator rarely come on even when I'm running on fumes. Ive also been having problems with my backlighting on the dash behind my speedometer. Sometimes it turns on and off.
  2. Oct 5, 2009 at 5:38 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Fuel door indicator? If you are talking about the gas pump with an arrow next to it, it doesn't go out. Check behind the right side tail light for the towing junction box. You may have a loose connection or it is bad. Also, try adjusting the dimmer switch when the backlighting goes out. It may be bad or have a loose connection also.
