2004 tacoma HID headlight problems (looks like crap and is all over the place)
Discussion in 'Lighting' started by kalin.nichols, Jun 6, 2011.
  1. Jun 6, 2011 at 1:09 AM
    kalin.nichols
    kalin.nichols [OP] Active Member
    Kalin
    Marysville, WA
    04 Tacoma TRD SR5
    I have a 2004 tacoma that has 6000k i have had 4300k 6000k 8000k 12000k and 30000k all on this same truck i have never been able to get that clean bright look that a lot of other cars and trucks have it always seems scrambled around even with a glare shield and i have noticed that the top part of the reflector is starting to get a burnt look almost like someone had a lighter it turned a fogy white instead of the mirror color is that from hids getting too hot or something it wasnt like that until recently when i had 12000k's hooked up is there anyway to get a clean straight beam without having to retrofit a projector by possibly messing with the aiming which i still havent been able to figure out
  2. Jun 6, 2011 at 1:11 AM
    kalin.nichols
    Kalin
    Marysville, WA
    04 Tacoma TRD SR5
    and i know that supposedly hid's run cooler then halogens and shouldn't melt or distort anything but i have never run any halogens on it since i bought it only hids the whole time
  3. Jun 10, 2011 at 6:24 AM
    4x4Tacoma01
    4x4Tacoma01 Well-Known Member
    Holly
    Canada Eh?
    SR5 Tacoma 4x4
    You will never get a clean cut off with a plug and play kit. You may get a better beam if you get a set of clear aftermarket headlights, like TYC. 4300k is the best imo, you have better light output.
    Your best bet is to retrofit, if you want it perfect :)
  4. Jun 12, 2011 at 10:46 AM
    carjunkie12
    carjunkie12 New Member
    Lift Kit
    Not sure why you're having this problem, where are you getting your kits from? Have they all been from the same place because you could just be getting cheap kits.
  5. Jun 12, 2011 at 10:54 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    You need to focus the light. Without doing that you aren't going to get the output you are talking about. Do some research on retrofitting the FX-R there are some great write-ups.
  6. Jun 16, 2011 at 10:56 PM
    leveltwo
    leveltwo Well-Known Member
    hid in stock housing = fail
