2004 Tacoma PreRunner TRD - Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by paulr22043, Sep 4, 2011.
  1. Sep 4, 2011 at 9:21 PM
    paulr22043
    paulr22043 [OP] Member
    paul
    McLean, VA
    04 PreRunner TRD Double Cab
    I purchased my Tacoma in April 2004; it has about 45k miles and the tires look good; I believe the tires will last another year or two. The tires are 265/70/16 BF. When I make the replacement, I would like to purchase larger tires. What are the largest tires I can put on the Tacoma w/out any modifications? Thank you for your help!
  2. Sep 5, 2011 at 5:33 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    265/75/16 in an all terrain tire is the largest size you can run on a stock setup with no modifications. That is also assuming you stick with the stock 5-star wheels.
  3. Sep 5, 2011 at 5:44 AM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
  4. Sep 5, 2011 at 3:22 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    ive got LT Michelin M/S2's i dont think the ride is too rough...
  5. Sep 5, 2011 at 7:15 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Wait, your truck has about 45k miles or the current set of tires do? I bought mine new in July 2004 and it has 101k. That's pretty low mileage for a 2004 if that's all yours has.
  6. Sep 6, 2011 at 4:40 AM
    paulr22043
    paul
    McLean, VA
    45k is it. I live pretty close to work. Based on the posts here, it seems I will not be able to step up the tire size unless I make a modification.
  7. Sep 6, 2011 at 8:19 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    yes you will. a 265/75/16 is larger then what you have
  8. Sep 6, 2011 at 8:22 AM
    Yamaha Dave
    ^ Exactly, like I mentioned above 265/75/16 is a larger size tire than what you are currently running and YES you can run this size with no modifications. I am on stock ride height and this is the size I am on.
  9. Jul 2, 2013 at 6:53 PM
    paulr22043
    paul
    McLean, VA
    Based on this thread, I think I can purchase the 265x75x16 without any modifications....Thank you.
  10. Jul 2, 2013 at 6:55 PM
    paulr22043
    paul
    McLean, VA
    Hmm, does that mean I have to replace the spare as well? I assume I could not ride with the spare 265x70x16 without causing problems....
  11. Jul 2, 2013 at 6:57 PM
    paulr22043
    paul
    McLean, VA
    Hmm, for some reason, I am having a hard time finding 265x75x16?
  12. Jul 5, 2013 at 7:20 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    265/75-16 is a VERY common tire size. It is a factory tire size for many vehicles. Check out tirerack for tire options in that size.
  13. Dec 30, 2014 at 3:04 AM
    paulr22043
    paul
    McLean, VA
    You are right, got them at Walmart. Will have them installed today/tomorrow. Original BG Goodrichs had 74k tread was still ok but lots of cracks.
  14. Dec 30, 2014 at 3:05 AM
    paulr22043
    paul
    McLean, VA
    Another question, the specs for the old tires said should be inflated to 26 psi. What about these tires b/c they are a little bigger?
  15. Dec 30, 2014 at 3:06 AM
    paulr22043
    paul
    McLean, VA
    Final question, different topic. I have trouble putting fuel in my gas tank, the gas dispenser seems to think the tank is full. Therefore, it clicks off and I have to put the gas in very slowly. Any ideas?
  16. Dec 30, 2014 at 3:45 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    your truck calls for 26psi front, 29psi rear, I drive a lot of cross country miles, have tried pumping the air up but get a rougher ride and tires wear faster in the middle...
    it just plains rides better at the factory PSI IMHO, the difference in MPG with a couple of pounds extra air is negligible...
    others will chime in with their experiences, I prefer smooth....
  17. Dec 30, 2014 at 6:53 AM
    paulr22043
    paul
    McLean, VA
    Thanks, I think my truck calls for 26 all around. Will double check this afternoon.
