2004 Tacoma Truck ABS light on Easy fix?
Discussion in '1st Gen. Tacomas (1995-2004)' started by felotacoma, Feb 12, 2021.
  1. Feb 12, 2021 at 5:40 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Well, I don’t want to trash this guys thread up with back and forth bickering, so this is where I’ll retire. However, I will always advocate for people to learn to do things the manual/no safety system way in addition to learning automation so we can continue to have skilled versatile people on the road, in the air, and anywhere else I’m qualified to have an experience based opinion on.
    Wyoming09 likes this.
  2. Feb 12, 2021 at 5:57 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you feel the federal Government should mandate Reto fitting of ABS brakes to all street legal vehicles in the United States at the consumers expense ?
    All vehicles having ABS brakes that now have obsolete parts can no longer be driven on the street??
  3. Feb 12, 2021 at 6:01 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    In a word.....Nope.
    Same answer to both questions.
  4. Feb 12, 2021 at 6:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My 98 did not have ABS.
    My 04 has it.
    I felt much more secure driving the 98 in sketchy road conditions. If my ABS went out tomorrow, I would lose no sleep being without it.
    ToyotaDriver likes this.
  5. Feb 12, 2021 at 7:04 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm sure he says it drives perfectly fine. He's trying to sell it to you.
    Have you verified this for yourself?
  6. Feb 12, 2021 at 7:09 PM
    jbrandt
    Justin
    You can run the vin, or just look for the factory locker on the rear axle. ALL TRDs (esp 2004's) had lockers. There were some earlier models that didn't but the 2004 would have a locker.
    Double cabs had tokikos, and the extracabs and reg cabs had bilsteins. But don't worry about the shocks, if they're still factory originals, they are 100% worn out and should be replaced anyway.
  7. Feb 12, 2021 at 8:42 PM
    koditten
    Kirk
    Central Michigan
    It is a 16 year old truck. It's not gonna be without a few issues.
  8. Aug 16, 2024 at 8:41 PM
    flockem
    flockem Member
    Rem
    I have a 2004 quad cab with locker and non trd. I suggest running the VIN
