2004 Toyota Tacoma 4x4
Discussion in 'New Members' started by khschneider01, Jan 15, 2012.
  1. Jan 15, 2012 at 11:05 AM
    khschneider01
    khschneider01 [OP] Member
    Karl
    Toronto,Ontario. Canada
    2004 Toyota Tacoma 5VZFE 4x4
    Hi : everyone I just joined, although ,I visited this site many times to browse around. I'm having trouble greeting everyone as a new member, also I do not know if this greeting is going to be posted in the right place ,if not ...my appologies. Anyway youll have to put up with me until, I can navigate around this site a little easier.
    I have one question regarding the lubrication of the driveshaft universals which is done, usually every 7000KM or between oil changes using (100% synthetic) What's the best way? Should I : Chock the front wheels,
    place the jack under the rear differential and raise the back wheels off the ground just enough to turn them(wheels) as i grease the universals ,turning the wheels should turn the driveshaft and in turn position the grease nipples that I can't connect with.
    Best regards Karl
  2. Jan 15, 2012 at 11:00 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  3. Jan 15, 2012 at 11:07 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
  4. Jan 16, 2012 at 3:33 AM
    khschneider01
    Karl
    Thanks for the reply Scorcar,Norton and m3bassman : At first I was crawling underneath and greasing the nipples that I could connect with and then ,crawl out , start the truck and back-up a short distance to reposition the driveshaft, so I could access the grease nipples I could'nt get too. My thought was, that if I jacked up on the differential enough to raise the tires off the ground, this would allow me to spin the wheels ,enough to turn the driveshaft to a new position. That way I could finish the job in a very short time. Chocking the front wheels would stop the truck from moving when I'm underneath .
  5. Jan 16, 2012 at 8:14 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
  6. Jan 16, 2012 at 11:34 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I do this as well.
    for the front driveshaft you can just turn it by hand as long as the transfer case is in 2wd.
    Also you don't have to grease the slip joint (the one in the middle not near any u joints) till it squirts out. I generally do about 7-10 pumps in that one and call it good.
  7. Jan 16, 2012 at 11:39 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    go to autozone, they have a nice grease gun there for pretty cheap.
  8. Jan 16, 2012 at 11:41 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    oh take that sucker back, thats ridiculous.
  9. Jan 16, 2012 at 11:42 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    If you take it to Jiffy Lube, say goodbye to your TW membership.
    You would be better off taking it to Krazie.
  10. Jan 16, 2012 at 11:42 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Did you open the nozzle?
  11. Jan 16, 2012 at 11:43 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    My truck had a jiffy lube sticker on the windshield when I bought it. the drain plug was torqued to about 4000 ft lbs along with the filter.
  12. Jan 17, 2012 at 3:06 AM
    khschneider01
    Karl
    Your right it is a lot of work ,but I don't have any friends that own a garage so alot of the repairs are done on the driveway,I also have a slight pitch , so chocking the wheels is mandatory for this job, because you can't apply the parking brake in order to do this job. I have a good grease gun and I purchased a flexable hose with a fitting ,so it's easier to get into more complicated places ,but still ,in order to to grease all the points the driveshaft must spin around at least 180 degrees.
    I want to thank the others for there input ,as this information was very good . Nothing nicer then talking to people that have been there before
    I gotta go now ...I'm at work.......Best regards to All ...Karl
  13. Jan 17, 2012 at 4:19 AM
    khschneider01
    Karl
    HeY m3basman: Don't throw that grease gun away ,They can sometimes
    be a pain to re-load and prime . I'll get some advice from a guy who greases the equipment here at work and i'll get back to you with a solution to this problem ,Give me 8 days, as I'm finishing my shift today
    Best Regards Karl.
  14. Jan 17, 2012 at 8:20 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :confused:
    You in fact can apply the parking brake to do this job. At least on my truck, all the grease fittings point in the same direction on the driveshaft so once I am able to get to one of them, I can get to all of them.
    Just getting it lined up initially is where you need to be able to roll it back a few inches.
    No need to jack up the rear of the truck or chock the wheels.
  15. Jan 17, 2012 at 8:39 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Welcome from SoCal!
  16. Jan 26, 2012 at 9:47 PM
    khschneider01
    Karl
    Thanks for the input Steve ...I am going to take another look at this job and see if this can be done on a 2004. I had a 2000, but had to give it up due to frame rot with only 142,000km.
  17. Jan 27, 2012 at 9:09 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
