2004 with p0302 ( or not ? )
Discussion in '1st Gen. Tacomas (1995-2004)' started by unfortunatetacoowner, Jan 22, 2021.
  1. Jan 23, 2021 at 1:12 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    That'll help tell if they're firing. However, you'll need to remove them and take them in to see if there's an issue with clogging or dripping. That's where O'reilly can come in. I'd be leaning more towards dripping if the plug is wet.. assuming the compression test is good.
  2. Jan 23, 2021 at 1:18 PM
    unfortunatetacoowner [OP] Active Member
    2004 Silver Tacoma
    Gotcha I have a pending p0302 code right now, so first thing to do I think is go get a compression tool and check the compression. After that I can rule that out and move onto fuel injectors ? Or can faulty / clogged fuel Injector mess with compression ?
  3. Jan 23, 2021 at 1:23 PM
    RedWings44
    Michigan
    I wouldn't believe so. The system should still be sealed and the fuel rail pressurized. The compression test should indicate too much blow-by, a sticky valve, or worse, a blown head gasket. I don't think fuel injectors would affect that.
  4. Jan 23, 2021 at 1:24 PM
    2004 Silver Tacoma
    Gotcha, headed to the store to loan a tool, will update with numbers
    RedWings44[QUOTED] likes this.
  5. Jan 23, 2021 at 1:25 PM
    RedWings44
    Michigan
    I'm hoping for the best for you!
  6. Jan 23, 2021 at 2:36 PM
    2004 Silver Tacoma
    Just got the 4 coils and spark plugs out, I need to pull the efi fuse and relay from the fuse box in the engine bay before starting yes? Both or just the fuse ?
  7. Jan 23, 2021 at 2:37 PM
    RedWings44
    Michigan
    I would imagine just one would be fine
  8. Jan 23, 2021 at 3:02 PM
    2004 Silver Tacoma
    Disappointing results
    1-180
    2-90
    3-180
    4-170
    What now :/
  9. Jan 23, 2021 at 3:05 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do a leakdown test and see where its going (valves, rings, or head gasket)
    RedWings44 likes this.
  10. Jan 23, 2021 at 3:06 PM
    RedWings44
    Michigan
    Now to try and figure out if you have a head gasket or valve issue. A head gasket issue would usually contain other symptoms such as milky oil or low coolant.
  11. Jan 23, 2021 at 3:08 PM
    2004 Silver Tacoma
    I think a good place to start would be a leak down test as dm93 said
  12. Jan 23, 2021 at 3:09 PM
    RedWings44
    Michigan
    Yes, that can be a good indicator. I'm not sure but I believe you'll likely have to take it to a dealership or repair shop to have that done.
  13. Jan 23, 2021 at 3:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If you have an air source and a compression tester with a 1/4 npt fitting or quick connect you can do it yourself. Just take the shcrader valve out of the compression tester, roll the engine to tdc compression on the cylinder you want to test, screw your compression tester hose in and hook air to it.
  14. Jan 23, 2021 at 3:27 PM
    2004 Silver Tacoma
    Unfortunately just read that aswell that I need air source, don’t have a compressor available, unless I ask around. I have a few connections at local shops and what not so maybe I’ll ask around if anyone can do. Heard that local tuners usually do this type of thing?
  15. Jan 23, 2021 at 3:31 PM
    #35
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Interesting. I recently got a p0304 code (cylinder 4 misfire). The truck would just run really bad at startup. So, I changed the spark plugs and replaced the coilpack with one from autozone's duralast brand. That was about 300 miles ago, and so far so good.
  16. Jan 23, 2021 at 3:33 PM
    #36
    2004 Silver Tacoma
    Thing is with the truck, it pulls decently , don’t really notice a loss of power , but it does shake / vibrate at idle
    crazytacoman[QUOTED] likes this.
  17. Jan 23, 2021 at 3:35 PM
    #37
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Yes that's what mine did as well, though I didn't drive it other than 10 yards until I fixed the problem
  18. Jan 23, 2021 at 3:35 PM
    #38
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A cylinder with low compression will tend to miss at idle but be fine at higher speeds if it's not too low.
  19. Jan 23, 2021 at 3:54 PM
    #39
    2004 Silver Tacoma
    I see, I will try and find a shop that can help me do a leak down and hopefully that locates the issue, i will update as I learn anything new. If anyone has anything to add please let me know!
  20. Jan 23, 2021 at 3:56 PM
    #40
    RedWings44
    Michigan
    That can cause the code too. But it won't cause a compression issue which OP seems to have.
