2004 with p0302 ( or not ? )
Discussion in '1st Gen. Tacomas (1995-2004)' started by unfortunatetacoowner, Jan 22, 2021.
  1. Jan 23, 2021 at 4:08 PM
    #41
    unfortunatetacoowner [OP] Active Member
    2004 Silver Tacoma
    Is it worth doing a wet compression test before returning the tool ( put a little oil in before connecting tool )
  2. Jan 23, 2021 at 4:15 PM
    #42
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That may tell you if it's rings or not.
  3. Jan 23, 2021 at 5:22 PM
    #43
    2004 Silver Tacoma
    Gotcha a friend has a air compressor so I’ll do the wet compression test tomorrow and also the leakdown test as harbor freight has a kit for $80 and I’ll probably just return it after
  4. Jan 24, 2021 at 2:35 PM
    #44
    2004 Silver Tacoma
    Did a wet compression test, same compression or so on the cylinder 2 that is misfiring
    RedWings44 likes this.
  5. Jan 24, 2021 at 5:25 PM
    #45
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Probably not rings then, a leakdown test will tell you where its going. A leakdown test is basically just pressurizing the cylinder with compressed air with both valves closed and the piston at TDC and listening to where it leaks out (intake, exhaust, crankcase, or cooling system), I'm betting your gona find a leaky exhaust valve.
  6. Jan 24, 2021 at 5:26 PM
    #46
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    And that would be the ideal situation over a head gasket in my opinion
  7. Jan 24, 2021 at 7:54 PM
    #47
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Not necessarily. It might mean a burned valve, which would require a cyl. head removal anyway, and more machine work. if it's just an adjustment of the valve, then yes.
  8. Jan 25, 2021 at 9:57 AM
    #48
    2004 Silver Tacoma
    I picked up the leak down test kit from harbor freight yesterday, my friend with the air compressor should come by today or tomorrow I will let you all know how it goes
  9. Jan 26, 2021 at 4:27 PM
    #49
    RedWings44
    Michigan
    Any updates?
    crazytacoman and JudoJohn like this.
  10. Jan 30, 2021 at 2:53 PM
    #50
    2004 Silver Tacoma
    Hey just did the leak down test, air coming out of cylinder one, thoughts
  11. Jan 30, 2021 at 3:19 PM
    #51
    2004 Silver Tacoma
    Sorry for the delay aswell, took a little bit to get things organized with the compressor but hopefully can get repairs rolling. From what my friend told me, its possible to be head gasket or the head needs to be replaced? Any other alternatives?
  12. Jan 30, 2021 at 3:22 PM
    #52
    RedWings44
    Michigan
    The only other thing I can think of is if the valve is gummed up and not wanting to move or not sealing. But more than likely you have something else at play too
  13. Jan 30, 2021 at 3:24 PM
    #53
    2004 Silver Tacoma
    oh also we cranked the pully to "make sure its at top dead center ( TDC ) " according to my friend who assisted
  14. Jan 30, 2021 at 3:27 PM
    #54
    2004 Silver Tacoma
    as for your theory, my friend replied that the air would be coming out of intake or exhaust in that case?
  15. Jan 30, 2021 at 4:37 PM
    #55
    RedWings44
    Michigan
    Yes, that would be accurate. At TDC, both valves should be closed. That leaves a head gasket as the most likely thing (I believe. I could be wrong). What does your oil look like? Also, do you have a lot of blow-by?
  16. Jan 30, 2021 at 4:52 PM
    #56
    2004 Silver Tacoma
    Oil from dipstick looks clean, I think we checked blow by, don’t recall that being a issue / present
  17. Jan 30, 2021 at 5:14 PM
    #57
    RedWings44
    Michigan
    That doesn't necessarily mean your head gasket isn't an issue, but still. Lack of blow by eliminates the piston rings as an issue at least. If it is the valves, yes it would be leaking out of either the intake or exhaust (as you mentioned), but I'm not sure how you test that, to be honest.
  18. Jan 30, 2021 at 7:26 PM
    #58
    JudoJohn
    St. Louis
    Where is it coming out? Is it coming out the intake or can you hear it in the exhaust pipe? that's a sure sign it's valve leakage. If it's coming out the coolant, then definite HG.
    If it's valves or HG, the head has to come off, either way.
  19. Jan 30, 2021 at 9:25 PM
    #59
    RedWings44
    Michigan
    I guess I forgot to clarify for myself. You have low compression on cylinder 2 and air coming out of cylinder 1. Does that mean your air from cylinder 2 is going to 1, or you're losing air in cylinder 1 in addition to low compression in #2?
  20. Jan 30, 2021 at 11:00 PM
    #60
    2004 Silver Tacoma
    Low compression on cylinder 2, cylinder 2 had normal compression compared to other cylinders. so it seems like air from cylinder 2 is going to 1
