2005-2008 4X4 TRD Off Roads - VSC/TRAC/HAC/DAC/ALSD/ATRAC explained
Discussion in 'Technical Chat' started by GP3, Oct 27, 2011.
  1. May 2, 2012 at 9:21 AM
    GP3
    GP3 [OP] Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    RSCA and VSC/TRAC/DAC were two separate options for 2008.
    If you had RSCA (roll sensing curtain airbags), you'd have a RSCA button. It was an option for 2005-2008 Double Cabs.
    If you had VSC/TRAC/DAC (Vehicle Stability Control/etc.) you would have a 'swervy car button' since your truck is a 2008. VSC/TRAC/DAC was an option for 2005-2008 TRD Off Roads.
  2. Feb 10, 2015 at 1:28 AM
    off road
    off road Well-Known Member
    So Calif
    2015 Double Cab TRD OR 4X4 & 2013 Reg Cab Base 4X4
    My buddy has a 2008 Double Cab, TRD SPORT 4X4 Long Bed. (It's a long monster!)
    I have not had a chance to drive it or experiment with his different modes, but it does have the swervy car button. (Have not had a chance to look at his brake booster, either.) Any idea what all he has? Any yellow wire mod possible for that year?
    He says it will go anywhere, and in all these years he has never gotten stuck. He is a geologist who does field work all over the western US....so when he says that, I tend to believe him!
  3. Oct 13, 2016 at 12:11 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I popped the blanks out of my dash to see what's behind it. I noticed there's wiring for the VSC button in my truck. I have a vacuum booster in a 2008 TRD Off Road. Any idea what would happen if I put in the VSC switch? I suspect nothing not having the electronic brake booster but curious if anyone knows.
  4. Oct 13, 2016 at 4:04 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Do it and let us know... There was optional TRAC/AUTO LSD before 2009 when they became standard in all Tacomas.
  5. Oct 13, 2016 at 6:09 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Looks like 'VSC OFF' is part 84988-04050 and will cost about $55. Ouch, that's not a cheap switch. I'll have to dig around and see if any of the other components are there before I try. It may just be a universal wiring harness.
  6. Oct 13, 2016 at 7:08 PM
    David K
    DaveInDenver likes this.
  7. Aug 18, 2017 at 10:57 PM
    David Loflin
    David Loflin 2012 Conversion
    David
    Raleigh/Mooresville NC
    2007/12 BSP AC High Country TRD Off Road
    2012 Front End Conversion RuggedT Decals Phillips 921 Led Reverse Lights and 43mm Dome Led Sylvania ZEVO LED Map, and License Plate Lights Silverstar ZXE Headlights and Fog Lights K&N Air and Oil Filter Panavise dash mount and Proclip phone holder Mobil 1 Synthetic 5w-30 Mobil 1 Synthetic 75w-90 diff oil Fumoto Oil Drain Valve Painted Engine Cover Shorty Antenna Partial Debadge and Rebadge High Country Badges from Silverado Secondary Air Filter Removed FJ 6 spoke OEM wheels Mastercraft Courser MXT Tires UWS Toolbox TRD Bislteins-4600s Recall Leafs Realtree Seat Covers Walmart All Weather Mats Rain X Wipers Belkin Multi Charger ran through Console Firestik NGP 3 foot Antenna Black exhaust tip
    i will report back in the morning, i just got a swery car button and have an 07 prerunner but my truck is wired up mostly as a trd off road would be, i have almost all the stuff for plug and play to add a elocker, the inverter and other things just from digging around,
    i had the switch plug but it was tied in up in a loom. pulled it out and plugged right up. will do the hold button and see. i have the standard no brake booster package.
    worst case scenario i use it for abs killswitch
  8. Aug 19, 2017 at 6:31 PM
    David Loflin
    David
    well no swervy car action for me, at least now i have a stock looking abs kill switch.
  9. Apr 17, 2018 at 12:10 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Has anybody swapped from vacuum boost to the TRD off-road booster? And is it hydro or electric?
    My 07 has the big vacuum donut
