2005-2011 Winch Mount Bumper - FREE SHIPPING
Discussion in 'Group Buys' started by usoffroad, Feb 5, 2014.
  1. Feb 6, 2014 at 7:52 PM
    usoffroad
    usoffroad [OP] TEXAN Vendor
    Brad
    Hico, Texas
    1998 4Runner and 1970 FJ40
    Sure...haven't tried it but you could grab a shackle with it.. probably the safest way.
    Outstanding! Added to the list.
  2. Feb 7, 2014 at 10:06 PM
    Poolstick
    Poolstick Well-Known Member
    So cool.. but $500...
  3. Feb 8, 2014 at 4:16 AM
    HighTideTaco
    HighTideTaco The Way Life Should Be
    Jon
    Maine
    2010 TRD Sport
    Swapped Hoods (!!!), DTRL Toggle Switch, Disabled seatbelt/ignition chime, Disabled lock/unlock beeps, Installed D-Rings in bed, Debadged "Toyota" on transom (now just one line straight across), Removed mud flaps, Removed TRD Stickers, Custom aluminum "ladder rack" with CB mount (Wilson 2000 Trucker; Uniden 520), WeatherTech; Just getting started!
  4. Feb 9, 2014 at 7:34 PM
    Halftunn50
    Halftunn50 Member
    Orange Co., NY
    Tacoma V6 Short Bed
    URD MAF Sensor Calibrator
    OK no problem. I can certainly Rhino it ...makes sense
  5. Feb 9, 2014 at 8:01 PM
    usoffroad
    Brad
    Hico, Texas
    The prototype for John is here on my bench. Been a bit cool so dry times are hours and as we have more cold weather on the way tonight I thought I'd get a head start.
    They key to a good finish is prep, just like anything else. We grind these down pretty good so you shouldn't have to do any metal work, nice and smooth but with plenty of texture for primer. Main thing is cleanup, machine oils, shop dust, metal fragments...they get wiped down a bit but in reality leaving the machine oils on them stops any flash rust. It takes some good wax & grease remover and plenty of shop towels then a good air blasting after they are dry.
    I've used all kinds of paints and coatings but this Rustoleum Professional paint works well. I used the Bed Liner on my boy's custom wagon tub and really like it. It's tough but the texture isn't like Linex but dries hard where Rhino's cold application of polyurea is a bit more rubbery (they have hot versions too now), but for 7.95 at just about any auto store or even Home Depot it works well. The primer covers well and while I typically use more commercial grade paints for projects I have no complaints here.
    I always spray the winch tub and underside where the gussets are first, 2-3 coats of primer and 2-3 coats of paint. The bed liner covers very well and drys a satin black with very minor texturing, about like a 120 grit sand paper.
    The pick below is wet primer, I'll try to grab some closeups of the bed liner tomorrow. Then I'll flip it over and prep/paint the visual part of the mount. May use the bed liner there too as John wants a satin finish.
    This is by far the most time consuming part of the install as you don't want to start monkeying with it until it's very dry. 60 some odd pounds of steel getting man handled will typically produce some scuffs and what not. Nice thing about the bed liner is that it's easy to touch up and will help hide any trail scars.
    More to come.
  6. Feb 10, 2014 at 11:56 AM
    fj40taz
    fj40taz Well-Known Member
    Carl
    Williamstown, NJ
    10 Toyota Tacoma
    Flowmaster Exhaust
    looks good so far.. I also want to do a matt or satin finish..
  7. Feb 14, 2014 at 3:31 PM
    Chaz84
    Chaz84 Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    Put my name on that list
  8. Feb 15, 2014 at 8:02 AM
    usoffroad
    Brad
    Hico, Texas
    Done.
    I'll have some painted pics today. We are going to do the full install Wednesday as well so I'll have final photography that evening.
  9. Feb 16, 2014 at 3:16 PM
    usoffroad
    Brad
    Hico, Texas
    Here's a few pics of the coated bumper.
    This gives you a pretty good idea of the Rustoleum bed liner texture I used for this. I like it so much I'm going to use it on my latest mount on my FJ. Covers gouges/scratches extremely well and provides a nice lightly textured satin finish.
    Closeup (no it doesn't come with shackles)
    With our Sirius 2" LED's
    and one more of the underside
    Looks like we will install this Wednesday afternoon and will have full install pics then.
  10. Feb 16, 2014 at 6:21 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    Is there any chance that this could be done for us tundra 07-13 guys, we are very interested on tundratalk.net
  11. Feb 16, 2014 at 6:43 PM
    usoffroad
    Brad
    Hico, Texas
    Yes, I've been eyeballing that big ol piece of plastic, it screams winch mount. I'm a member over there but I won't do business with any AutoGuide sites for a laundry list of reasons. Nothing against the membership of course, simply the owners. So I won't be discussing it over there.
    I need more R&D assets I can tell...
    Give me a shout via my website with your info and we can talk more.
  12. Feb 17, 2014 at 7:56 AM
    fj40taz
    Carl
    Williamstown, NJ
    10 Toyota Tacoma
    Flowmaster Exhaust
    looks good i like the finish.....
  13. Feb 17, 2014 at 8:26 PM
    mloco575
    mloco575 Well-Known Member
    CT
    2011 TRD Sport DC long bed
    I'm defiantly down for one of these!
  14. Feb 18, 2014 at 8:40 AM
    Halftunn50
    Halftunn50 Member
    Orange Co., NY
    Tacoma V6 Short Bed
    this just gets better looking each day...can't wait to see the install pics!
  15. Feb 18, 2014 at 8:47 AM
    #35
    Halftunn50
    Halftunn50 Member
    Orange Co., NY
    Tacoma V6 Short Bed
    Dumb question.....if you currently have the Aluminum "Show skid plate" installed
    Will this still bolt up or is the point moot trying to put that thing on in front of your new winch bumper?
  16. Feb 19, 2014 at 8:15 AM
    #36
    JayB27
    JayB27 Well-Known Member
    Orange County, CA.
    10' White DCSB Pre Runnner
    Debadged, Plasti-Dip Wheels, Color Matched Satoshi grille, Ebay Seat Covers =P, Painted Black and white Radio surround, Blue Interior Dome light, White Maps lights, Fishing Rod Holder. All done by me.
    Pretty sure this is to replace the skid plate and the lower plastic cross member piece.
  17. Feb 19, 2014 at 8:32 AM
    #37
    usoffroad
    Brad
    Hico, Texas
    That is correct. You will have a real skid plate now.
    Oh... and forgot to post this but it weighs exactly 67 lbs.
  18. Feb 19, 2014 at 8:33 AM
    #38
    usoffroad
    Brad
    Hico, Texas
    You got it.. you are on the list.
    Doing the install tomorrow and will post pics immediately afterwards.
  19. Feb 19, 2014 at 1:44 PM
    #39
    JayB27
    Orange County, CA.
    I'm looking forward to seeing the installed pics as well.
  20. Feb 21, 2014 at 11:41 AM
    #40
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    Picssss
