2005-2015 Morimoto Mini D2S Bi-Xenon projector install guide
Discussion in 'Lighting' started by TRSAndrew, May 4, 2015.
  1. Jul 29, 2015 at 10:59 AM
    ProjectMAX
    ProjectMAX Well-Known Member
    Georgia
    2006 Black Tacoma Prerunner
    D2S Retrofit 3" lift BFG A/T KO 285/75/R16 Flowmaster 40 BHLM Kenwood Excellon Doors and Subs 2x10 w/ 500W amp
    Ive seen people cut the nut on the back of the projector to make it fit in the space. that's the only other way I've seen it done. Especially with the newer kits, I guess some of the hardware is different from old write ups on here. I followed this guide and had no trouble whatsoever. The only hard part is opening the light so don't let the cutting deter you from doing this. Personally, after doing this I would've much rather gone with the FX-R projectors and cut my reflectors to hell. If you don't have a Dremel or sander, go pick one up they'll come in handy on other projects around the house. You're going to drop $300+ on projectors so $100 for a tool you're probably gonna use in the future at some point is worth it.
  2. Jul 29, 2015 at 12:04 PM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    I'm curious how long it takes the first timers to get this done? I'm sure the guys who've done a bunch have got the hang of it but I'm wondering what the general consensus is to complete this project. Half a day? All day? A couple of days?
  3. Jul 29, 2015 at 12:09 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    i took a day including painting. first retrofit i tried
    Dr. Jekyll[QUOTED] likes this.
  4. Jul 29, 2015 at 12:24 PM
    ProjectMAX
    Georgia
    It took me all weekend just because I wanted the paint to dry all the way. Without painting and starting at the right time, you could be finished in about 3-5 hours. A lot of time is wasted waiting on paint to dry, for the sun to go down.
  5. Jul 29, 2015 at 11:32 PM
    TJRTACOMA
    TJRTACOMA Well-Known Member
    Tony
    Rialto, CA
    07 Speedway Blue Tacoma TRD Sport
    Billet Grille, Pop N Lock
    Thanks fellas I actually painted mine about a week ago. Should be getting the kit on Friday. So if I have to grind I will have to take the bowls off as well.
    ProjectMAX likes this.
  6. Jul 30, 2015 at 2:09 PM
    ProjectMAX
    Georgia
    Let us know how it turns out!
  7. Sep 28, 2015 at 1:53 PM
    Mr. Ed's taco
    Mr. Ed's taco Well-Known Member
  8. Feb 7, 2016 at 8:33 AM
    bravosvo
    bravosvo Active Member
    For a 2006 Tacoma: Does the hardware or projector in newer D2S retrofit kits require you to grind down the back (even for a 2006)? That would not allow the "centering key" to do it's job. I installed an older TRS D2S retrofit kit in my 2006 w/o any grinding down and it worked fine.
  9. Feb 9, 2016 at 4:14 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I could be wrong but their newer version's shaft is shorter. Also, the h4 adaptors won't work since toyota rotated it (drivers side i think) for some reason.
  10. Feb 11, 2016 at 1:48 PM
    TRSAndrew
    TRSAndrew [OP] Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    I have an 05-11 reflector here in the lobby and it is keyed correctly. As long as you use the tiny knurled nut (if we are still even including these with the Mini D2S 3.0s, I'm not sure), no cutting is required at all. If we are not including these, there will be a little cutting required to use the larger hex lock nut.
  11. Feb 15, 2016 at 11:41 AM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    How do you run the wires coming off the solenoid through the boot?
  12. Feb 16, 2016 at 11:28 AM
    TRSAndrew
    ATL
    Next to the bulb and with an 80mm rubber dome-style housing cap
  13. Feb 16, 2016 at 12:25 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Where do yo get that 80mm cap?
    B3NDR likes this.
  14. Feb 16, 2016 at 12:44 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
  15. Feb 16, 2016 at 12:47 PM
    #35
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Thank you this will help grow the balls for the install
  16. Feb 16, 2016 at 12:52 PM
    #36
    deeezy
    Dana
    Hawaii
  17. Feb 16, 2016 at 2:27 PM
    #37
    TRSAndrew
    ATL
    I checked some of my other build threads and couldn't find any of the back of the housing, but the 80mm is a very good fit.
  18. Feb 16, 2016 at 2:46 PM
    #38
    deeezy
    Dana
    Hawaii
    So, it's just to seal the back of the bulb better?
  19. Feb 17, 2016 at 6:49 AM
    #39
    TRSAndrew
    ATL
    Correct
    deeezy likes this.
  20. Mar 11, 2016 at 9:28 AM
    #40
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Just to clarify something for me: When doing a retrofit like this you can paint the reflector bowl black since it's not being used to reflect light, rather the light is being projected from the new retrofit pieces? So everything can be painted black and not left silver?
