2005-2016 Tacoma Axle Codes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Dec 30, 2015.
  1. Dec 30, 2015 at 12:41 AM
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I've seen I don't know how many threads about this over the years, including one recently in the 2016 section, so I thought I'd explain. In the past (pre-1990's), Toyota had a system of axle codes common across all models and years, but with more and more axles being developed, it was no longer a viable system, and so a new one was introduced. The new system (used since then on all new models introduced after 1990 or so) cannot be applied to all vehicles, and so is much harder to define. The first letter is the ring gear size, generally A is the smallest ring gear size, B would be larger, and so on. The second 2 numbers are the gear ratio, starting at 01 and going up based on ratios used on that model. The last letter is the options the differential has, often A will be an open diff, B will be an LSD or locker and so on.
    These are different for every model! A01A on a 2002 4Runner will be a completely different differential than A01A on a Tacoma or even on a 2003 4Runner!
    As the 2016 Tacoma is still the same frames/type as the 2005 to 2016, the axle codes go on from there.
    A = 8.0"/205mm
    B = 8.8"/225mm
    01 = 3.583:1
    02 = 4.100:1
    03 = 3.153:1
    04 = 3.727:1
    05 = 3.307:1
    06 = 4.300:1
    07 = 3.909:1
    A = Open
    B = E-Locker
    C = Limited Slip Differential
    Jeff
  2. Dec 30, 2015 at 7:13 AM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Door jamb.
  3. Mar 30, 2016 at 5:00 PM
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Hey did you happen to find your axle code and can I ask what It is ?
  4. Mar 30, 2016 at 6:08 PM
    Jeff Lange
    Calgary, Canada
    It's on the compliance sticker in the driver's door jam.
    Jeff
  5. Sep 22, 2017 at 1:12 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  6. Feb 2, 2018 at 11:22 PM
    JDG2TACOMA
    JDG2TACOMA Member
    2015 Tacoma Sport
    My 2017 offroad is A04D. Last letters only go A-C. Anyone know about my code?
    jhunter80 likes this.
  7. Mar 7, 2018 at 3:14 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  8. Mar 7, 2018 at 3:15 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  9. Apr 23, 2018 at 4:12 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Good info, thanks OP
  10. May 31, 2018 at 12:00 PM
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    Hmmm. My TRD OR (E-locker) has A04C, which according to this is 'Limited Slip' not E-locker..Mine has an E-locker..Hmmm
  11. May 31, 2018 at 12:41 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Your signature shows you have 1997 Tacoma. The original post states the axle codes are only 2005+
  12. May 31, 2018 at 3:30 PM
    Taco crazy
    Chattanooga TN
    I have a ‘97 standard cab V-6 truck and a ‘15 double cab TRD OR.
    downhillbik3r[QUOTED] likes this.
  13. May 31, 2018 at 5:01 PM
    Jeff Lange
    Calgary, Canada
    Since posting this, I have come across a couple of inconsistencies I haven't worked out yet. There are a couple year/combinations that seem to be different for some reason.
    A04 is right, as it is an 8-inch 3.73:1 for a 2015 Tacoma TRD OR. The C being used for an e-locker is an interesting one though. I'd be interested to see some others from that time frame to compare to.
    The last letter being an A is definitely an option diff, and B/C/... are going to be something else (LSD, locker, etc.).
    I'm still looking into this further, I wish Toyota had lookup charts for axle codes.
    Jeff
    shakerhood likes this.
  14. Jun 1, 2018 at 4:59 AM
    Taco crazy
    Chattanooga TN
    Understood. I can assure you that's a factory TRD OR truck and that axle code is correct, just so you know.
  15. Jun 27, 2018 at 9:56 AM
    skubasteve828
    skubasteve828 Member
    2013 DCSB Offroad
    OME Lift, CBI bumpers, Warn Winch, sliders, skids ordered, LED's, roof rack, Softtopper
    my 2013 TRD Offroad has A04C
    TACOVRD likes this.
  16. Jun 27, 2018 at 10:50 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    It is not uncommon for people to slap TRD OR or Sport stickers on trucks, it is a little more uncommon for people to actually follow through with swapping in an elocker axle but it's not unheard of. Still if enough people chime in and have the same code/combo then winner!
  17. Jun 27, 2018 at 11:01 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    My 2017 off-road says "B07B" or 8.8", 3.909:1, E-Locker
  18. Jun 27, 2018 at 11:03 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I'd wager 3rd gens are going to be different codes. I mean they're certainly more leaky than 1st or 2nd gens.
    toofast4u752 likes this.
  19. Jun 27, 2018 at 1:14 PM
    #4TOY4ME
    #4TOY4ME Now driving #5
    Robert
    Kingman AZ
    17 MGM OR 4X4 AC
    Level 8 Mk6 16x8 0 offset , Bilstein 5100 G4 Elite Fold A Cover
    That's exactly the code on my truck.
  20. Jun 27, 2018 at 1:41 PM
    Taco crazy
    Chattanooga TN
    Yeah I get that, I've been driving and working on Tacomas since 1996. All I was saying is that my truck is a real TRD OR, I have the window sticker, it has all the supporting options etc..
