2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Jul 5, 2016 at 8:32 PM
    #301
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Bryan, can you please share the part number for the B110's you used?
  2. Jul 5, 2016 at 8:35 PM
    #302
    kumz
    kumz Well-Known Member
    I ended up moving my shackle mounts 1.25" forward from the forward most position. Shackle angle is now perfect with dakars. Ill try to post a pic if I can get photobucket to upload.
    Littles and ARCHIVE[OP] like this.
  3. Jul 5, 2016 at 8:39 PM
    #303
    ARCHIVE
    Eric
    Thank you, please do
  4. Jul 6, 2016 at 6:55 AM
    #304
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    This probably what I am going to do. Looking forward to seeing it
  5. Jul 6, 2016 at 6:57 AM
    #305
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Ordered from @Wheeler's Off-Road, Inc
    Part # BE5-B110-T5
  6. Jul 6, 2016 at 10:42 AM
    #306
    kumz
    Full droop/compression
    Ride height
    This setup is moved 1.25" forward of the forward most hole in the archive mount. I ended up drilling 3 additional holes in the archive mount, and 2 additional holes in my frame. I still have the cross member bolted in. If you guys need more pics, let me know. I am running dakar springs, icon extended travel shocks.
    singletrack_ftw, Durdy, Crom and 4 others like this.
  7. Jul 6, 2016 at 10:55 AM
    #307
    Pigpen
    Dan
    Northwest Montana
    I'd love to see more. I'm still on the fence on this kit for the reason of the shackle angles. My B110s and Dakars are on the truck and I just got my 29" brake lines in the mail yesterday.
    Thanks!
    singletrack_ftw likes this.
  8. Jul 6, 2016 at 11:44 AM
    #308
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    If I could achieve the angles you are showing in your pictures Kumz I would be all over this.
    Mr.PowerTrays and Pigpen like this.
  9. Jul 6, 2016 at 11:47 AM
    #309
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You did a good job Kumz! I wish this kit allowed for these angles right out of the box.
  10. Jul 6, 2016 at 11:50 AM
    #310
    Pigpen
    Dan
    Northwest Montana
    x2
  11. Jul 6, 2016 at 11:53 AM
    #311
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    We've been thinking of doing this with the all pro expo pack, and 12" kings
  12. Jul 6, 2016 at 12:00 PM
    #312
    deeezy
    Dana
    Hawaii
    Just by looking at Kumz's pics, he gained more droop by having his shackle at more of a 45 degree at ride height. You can see how much more the shackle moves now compared to how it was originally (closer to vertical at ride height).
    Mr.PowerTrays likes this.
  13. Jul 6, 2016 at 12:04 PM
    #313
    Pigpen
    Dan
    Northwest Montana
    Yeah, it looks good. I'm looking for an out of the box bolt on that accomplishes this.
  14. Jul 6, 2016 at 12:24 PM
    #314
    kumz
    Its very very simple to do. Just a matter of drilling a few more holes. Id even recommend to archive to drill more mounting holes in the shackle flip. Gives much more adjustability with spring packs of different lengths or ride height.
    As for the droop - I didn't gain very much by moving the bracket forward. It brought my ride height back to where I wanted it, and smoothed out the ride a bit. Ill try to get full profile shots of the truck with the axle drooped out. My leaf pack is now the limiting factor. Still got like an inch left in the shock. Had to extend the TRD E locker harness about an inch as well. Lots of travel :bananadance:
    Crom, ARCHIVE[OP], Littles and 2 others like this.
  15. Jul 6, 2016 at 12:26 PM
    #315
    Pigpen
    Dan
    Northwest Montana
    Perfect. I'm not looking for lift out of this, just a good ride and LOTS of droop. MOAR PICS! Thanks
  16. Jul 6, 2016 at 12:33 PM
    #316
    kumz
    Yeah, initially I had around 1.5" of lift on top of the Dakar pack. I ride motorcycles a lot, and am a borderline midget (5'5"), so it got pretty interesting loading bikes in the truck lol. I didn't want to crank my coils to the max either. Big fan of lowest ride height possible. By moving the mount forward, its back to my normal ride height. Im super stoked on this kit.
  17. Jul 6, 2016 at 12:49 PM
    #317
    Adventurous
    Colorado
    15 DCLB SR5
    Please Archive sir, would you be so kind as to have a few additional holes lasered out that are in line with what Kumz did?
  18. Jul 6, 2016 at 12:52 PM
    #318
    Pigpen
    Dan
    Northwest Montana
    Or at least drilled
  19. Jul 6, 2016 at 3:48 PM
    #319
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    This product looks awesome!
    Sorry, I may have missed this in the thread and not that familiar with rear suspension stuff.
    Want to confirm this will work with ICON mini 3 add a leaf pack + King 2.5 shocks?
    Edit: Strike this "Will I need limit straps since I am not running extended travel shocks?" I am running extended travel shocks.
  20. Jul 6, 2016 at 3:51 PM
    #320
    Pigpen
    Dan
    Northwest Montana
    Without extended travel shocks, there's no real reason to do this.
    deeezy likes this.
