2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Jul 6, 2016 at 6:44 PM
    #321
    TXGnftr
    TXGnftr Well-Known Member
    Texas
    Can someone help clarify position...by moving flip kit forward, does that increase additional lift? Or by moving mounting location of flip kit aft increase lift?
  2. Jul 6, 2016 at 6:51 PM
    #322
    kumz
    kumz Well-Known Member
    Moving it forward increased shackle angle, decreasing ride height.
  3. Jul 6, 2016 at 6:53 PM
    #323
    TXGnftr
    Texas
    Appreciate clearing that up...
  4. Jul 6, 2016 at 9:10 PM
    #324
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Got it. Thanks.
    Edit: I just looked at my purchase history and realized that my Kings are extend travel shocks, does that mean I can use these with my current set up?
  5. Jul 7, 2016 at 9:09 AM
    #325
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Did you do anything with your bumps to limit up travel? With your shackle as far forward as it is, it doesn't look like you're getting as much negative arch at compression as compared to the pre-drilled location.
  6. Jul 7, 2016 at 9:14 AM
    #326
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You would need to compare the ext/coll #'s of your shock. The best way would be to install this kit and take measurements to order custom length.
  7. Jul 7, 2016 at 10:01 AM
    #327
    Pigpen
    Dan
    Northwest Montana
    You need to know the actual numbers. Ideally your springs should limit travel near full extension of the shocks. As deeezy stated, you could install this and then make the appropriate changes
    I would put one side to full droop and get a measurement of the shock. Then remove the shock and take a full extension measurement. If you're close, installing this will mean buying new shocks. If you have a few inches of shock travel left, this kit might get you where you want to be.
  8. Jul 7, 2016 at 10:05 AM
    #328
    kumz
    Yes, needed to space the bump stops out more due to the longer shock.
  9. Jul 7, 2016 at 10:14 AM
    #329
    alvinfromhawaii
    Northern California
    Thanks for the advice. I will try this out.
  10. Jul 7, 2016 at 10:16 AM
    #330
    Pigpen
    Dan
    Northwest Montana
    How far did you space them? I'm on airbags for bumps and not sure if I'll keep them.
  11. Jul 7, 2016 at 10:20 AM
    #331
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    ^^^ @ARCHIVE this is the only reason i haven't ordered your product yet, please redesign a bolt on kit so proper angles can be achieved and you sir will have another customer :wave:
    RacecarGuy, Adventurous and Pigpen like this.
  12. Jul 7, 2016 at 10:26 AM
    #332
    Pigpen
    Dan
    Northwest Montana
    I would be (not too far) behind you. I still need to finish my front work still...working man problems.
  13. Jul 7, 2016 at 10:27 AM
    #333
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Ive got like 15 to 20 ° at ride height with the stock location for tge shackle mount im running dakars
  14. Jul 7, 2016 at 10:33 AM
    #334
    kumz
    i think 3/8. This takes some trial and error though, depending on length of your shock. I have the super bumps, and when it touches the frame, i have around 1.25" left in the shock before it bottoms. took the squish into consideration.
  15. Jul 7, 2016 at 10:34 AM
    #335
    Pigpen
    Dan
    Northwest Montana
    I forget - are you on B110s?
  16. Jul 7, 2016 at 10:36 AM
    #336
    kumz
    No. 56503-R EXT Icons
    Pigpen[QUOTED] likes this.
  17. Jul 7, 2016 at 4:47 PM
    #337
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    This is a great development! The shackle angle was the only thing bugging me about this kit. The parts themselves are really well made, just didn't like the positioning. Thanks for posting your findings brother! I'll be using your experience as a guide for my install.
    kumz[QUOTED] likes this.
  18. Jul 7, 2016 at 5:02 PM
    #338
    kumz
    No prob. Id definitely go off what springs you have prior to drilling any holes. I don't have an exact measurement of the all pro springs, but hear they and the stock pack is longer than the Dakar pack. A little forward definitely goes a long way.
  19. Jul 7, 2016 at 5:04 PM
    #339
    weldo
    Pittsburgh, pa
    Anyone know if this kit would work with Chevy 63s? Or do you have to move the shackle mount rearward for those?
  20. Jul 7, 2016 at 5:08 PM
    #340
    Pigpen
    Dan
    Northwest Montana
    @SMKYTXN
