2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Jul 21, 2016 at 7:58 PM
    #381
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    David, Im on track to take orders for revised brackets August 1st, probably could have a kit done and shipped 1st week in August
    I've only got 1 left of current state, so new rev is coming asap
  2. Jul 21, 2016 at 8:35 PM
    #382
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Awesome. Ive decided I need a shackle flip too, and running dakars.
  3. Jul 22, 2016 at 3:43 PM
    #383
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    Sweet tits, you make the best one on the market.
  4. Jul 24, 2016 at 6:21 PM
    #384
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Hey Eric, I'm thinking of going SUA. Is it possible to fit a 14" shock without cutting the bed? Or if the bed must be cut somewhat, can a tower be made sufficiently stiff to not require a bed cage for stiffness?
    I'm super interested in the relocate. I know it'll be a super high quality part just like a shackle flip! Can't wait to hear more!
    ARCHIVE[QUOTED][OP] likes this.
  5. Jul 24, 2016 at 6:33 PM
    #385
    ARCHIVE
    Eric
    14" travel shocks are possible without cutting the bed, and without having the lower axle mounts scraping the ground, and I believe I have it worked out for enough stiffness. A shock tower bar crossed my mind though.
    I also will have an affordable SUA conversion kit available very soon. The shock relocation could be several weeks out though
  6. Jul 24, 2016 at 7:07 PM
    #386
    ARCHIVE
    Eric
    The 14" travel shocks I'm referring to are full length 2.5" body Kings or Fox shocks like 983-02-098 with compressed lengths about 23.4" and extended length about 37.4"
  7. Jul 25, 2016 at 5:28 AM
    #387
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Go look at the 2013 build on Total Chaos website. It has their MT SUA with 14s under the bed. Although I believe they did run a cross brace between the two hoops on that build. That part was above the wheel wells and a space saver.
  8. Jul 25, 2016 at 6:24 AM
    #388
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    So this flip kit will work with the AP Expo pack? I'm looking at these as well
  9. Jul 25, 2016 at 6:51 AM
    #389
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    Another question--I currently have the original ATO shackle flips (only work with stock springs) would I need to add any extra holes for these or can I use the existing ones on the frame?
  10. Jul 25, 2016 at 7:08 AM
    #390
    2ndGenJonny
    Jon
    Gilbert, AZ
    I believe all shackle flips use the OEM holes. Some have 3 holes on the upper and shackle hanger for setting the shackle angles and differences in leaf packs.
    ARCHIVE[OP] likes this.
  11. Jul 25, 2016 at 7:12 AM
    #391
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    I run these with the all pro expo's and they work great. After an adjustments this weekend, i'm now sitting at 45* at ride height. I'm running them in the forward most position which requires drilling 1 new whole in the frame, took about 3 seconds to drill it, other bolts use factory locations.
  12. Jul 25, 2016 at 8:28 AM
    #392
    ARCHIVE
    Eric
    Thanks Jared @utroda for answering Erik's questions. I agree and think the Allpro expos are a good option, their length is ideal. But there are several good options available.
  13. Jul 25, 2016 at 8:36 AM
    #393
    ARCHIVE
    Eric
    Thanks Jon
  14. Jul 25, 2016 at 8:37 AM
    #394
    2ndGenJonny
    Jon
    Gilbert, AZ
    you got it man! Im excited to see your new products!
  15. Jul 25, 2016 at 12:03 PM
    #395
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    Once I get these new shocks installed (12" king smoothies) I have a feeling this week be my next purchase, just to get that last little bit of clearance :)
  16. Jul 25, 2016 at 12:46 PM
    #396
    2ndGenJonny
    Jon
    Gilbert, AZ
    Be a good idea to set it all up at the same time. 12s, relocate and flip. That way you know where to set the 12s for bump and droop.
    That way you dont end up like Ace and needing to redo it all
    utroda likes this.
  17. Jul 25, 2016 at 1:55 PM
    #397
    weldo
    Pittsburgh, pa
    Thanks Jon. The TC kit was the one I was looking at the hardest. Most guys say the DMZ kit is best but those guys also recommend 16" shocks and a bed cage. I don't think I need the DMZ kit, I'm only running a mild mid travel up front and don't plan to go long travel. I also like that the TC kit uses the stock mounting locations for the springs. Makes a simple install.
    Any details on this? Will you be using the stock locations like the TC kit? Will springs be included? Sounds cool Eric, good parts are worth the wait!
  18. Jul 25, 2016 at 2:11 PM
    #398
    weldo
    Pittsburgh, pa
    I'm really digging this design from the 2014 Total Chaos Tacoma build. 14" shocks without cutting the bed with the DMZ SUA kit. I like the plates bolting to the fender wells. That would add much stiffness.
    total-chaos-project-4x4-tacoma-expedition-truck (6).jpg total-chaos-project-4x4-tacoma-expedition-truck (7).jpg
    Mad T, DistortedAxis, Ariyan and 3 others like this.
  19. Jul 25, 2016 at 6:31 PM
    #399
    ARCHIVE
    Eric
    It will use the stock mounting locations, Deaver HD U539/U540 packs recommended, I now am a Deaver distributor
    Conversion kit is probably only a week or two away. It will include 1/2" thick upper U-bolt plates with air bump landing area, strong 9/16" U-bolts, SUA specific spring perches and 304 stainless lower U-bolt location plates featuring better ground clearance than DMZ lower plates.
    Pricing will be about $280, plus cost of springs.
    This is a great design, I figure its going to be $$$ if they produce them, rightly so.
    I plan to have my relocation be sub $300
    2ndGenJonny likes this.
  20. Jul 25, 2016 at 6:35 PM
    #400
    weldo
    Pittsburgh, pa
    Cool! Sounds good. Eagerly awaiting. Will you be reusing the oem inverted shackles?
