2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Aug 11, 2016 at 2:00 AM
    #461
    nastyneight
    nastyneight Well-Known Member
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    Gotcha, yea I've seen there site they do look good. Are you glad you have it?
  2. Aug 11, 2016 at 7:01 AM
    #462
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    How much lift did you get in the rear after installing the shackles? I never have any weight in the bed so I'm hoping to only get like an additional inch of lift max. I don't like the rake look
    Edit: never mind, I forgot that you did your flip and springs at the same time
  3. Aug 11, 2016 at 10:05 AM
    #463
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I have no regrets buying any of my skids. I do stupid stuff, so I've used every one of them.
    G.T. and nastyneight[QUOTED] like this.
  4. Aug 11, 2016 at 10:08 AM
    #464
    nastyneight
    Nathan
    Wilmington NC
    08 4DR S-Bed
    White Truck
    cool, diff skid only one i dont have.
  5. Aug 11, 2016 at 6:31 PM
    #465
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Just ordered the Billies. I'm going to run these while waiting for the OPS relocation kit for now. Thanks again :thumbsup:
    Crom[QUOTED] likes this.
  6. Aug 12, 2016 at 5:03 AM
    #466
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Hey, I'm running Dakars as well. I also have B110's on the way.
    Did you install those brake lines? I'm wondering what length to get myself. I'm sure 29" would be long enough. I just don't want them hanging down any more than necessary.
    Thank you
  7. Aug 12, 2016 at 7:15 AM
    #467
    Tacoma SS
    Denver
    I have 29s, with a 3 inch lift they don't hang
    ARCHIVE[OP] likes this.
  8. Aug 12, 2016 at 7:29 AM
    #468
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Great. Thank you.
  9. Aug 12, 2016 at 7:33 AM
    #469
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Thanks for responding, where are you guys getting the 29" ? Wasn't a chap on TW making them?
    Stock length on a 2011 I measured is 20" overall
  10. Aug 12, 2016 at 7:37 AM
    #470
    Pigpen
    Dan
    Northwest Montana
    @OCTaco sells them. His friend makes them.
    OCTaco likes this.
  11. Aug 12, 2016 at 7:47 AM
    #471
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yup. That's where I'm getting mine.
    OCTaco and Pigpen[QUOTED] like this.
  12. Aug 12, 2016 at 10:53 PM
    #472
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    @Mademan925 these are pretty nice for a shackle flip kit
    Mademan925 likes this.
  13. Aug 15, 2016 at 8:49 AM
    #473
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    What up! I can definitely set you up with those lines. Shoot me a PM if you have any questions.
    JP
  14. Aug 15, 2016 at 9:19 AM
    #474
    Tacoma SS
    Denver
    I already have them...
  15. Aug 19, 2016 at 11:02 AM
    #475
    ARCHIVE
    Eric
    The 1st Archive spring under axle conversion kit shipped out, should have pics of install hopefully by end of September. Sorry about the cheezy mock up
    @weldo
    Edit: a few details here.
    This conversion kit is made to retain and work with stock axle perch, the 1/2" thick HD bump plate has a locating pin for the stock perch, and the plate is made from 50,000 psi steel. The lower spring plate is 1/4" stainless to conform to curvature of spring and distribute pressure from the U bolts which are 9/16"
    Dogg23, G.T. and SonnyBones like this.
  16. Aug 19, 2016 at 11:29 AM
    #476
    Tacoma SS
    Denver
    I guess I don't understand what the benefit of doing this would be
  17. Aug 19, 2016 at 12:06 PM
    #477
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    It's for go fast people.;)
  18. Aug 19, 2016 at 12:43 PM
    #478
    Tacoma SS
    Denver
    To limit axle wrap or what?
  19. Aug 19, 2016 at 12:48 PM
    #479
    ARCHIVE
    Eric
    The trucks come stock with flat springs and 2.5" uptravel. The conversion to SUA allows more uptravel without going into negative arch, which to spring manufacturers isn't ideal. The Deaver springs also droop very well
  20. Aug 19, 2016 at 1:52 PM
    #480
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Looks cool. Is it wrong that I'm more worried about when my shackle flip will ship? :D
