2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Jan 15, 2016 at 5:34 AM
    #41
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    Toytec
    ARCHIVE[QUOTED][OP] likes this.
  2. Jan 15, 2016 at 6:49 AM
    #42
    Avex
    Avex Well-Known Member
    Alex
    PNW
    Tagged for later
  3. Jan 15, 2016 at 8:24 AM
    #43
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Don't think there is one yet. Looks promising but personally I don't want to be the guinea pig. Would like to see a few people running it and abusing it.
  4. Jan 15, 2016 at 8:39 AM
    #44
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    I am running it and so far its great
    The advantages i say were
    Adjustabe in 2 positions
    Greaseable shackle bushing
    Flip is built to the taper of the frame rails
    No more stock shackles which arnt greaseable and i have bent a few
    New shackles are 3/8304 stainless which is plenty strong
    Great company to work with
    Will post pics today
    bobsuruncle and ARCHIVE[OP] like this.
  5. Jan 15, 2016 at 8:46 AM
    #45
    imageomega
    imageomega Well-Known Member
    Jarrod
    If I'm thinking about this right... 5100's up front (not maxed out) + this in the back = relatively leveled with about +1.25" (rear) and +2" (front) lift? Because thats not bad for ~$450 when going to 2.5" and 3" approaches $1k for a reasonable set up (AAL at minimum and coils up front).
    Man I miss the "poor mans lift" option from the Xterra. $60 shackles + an hours work on the torsion bars up front, alignment and your done. 2 inches for $60. Awesome.
    RockyMtnTRD likes this.
  6. Jan 15, 2016 at 8:47 AM
    #46
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Subbed, One more awesome thing out of OP (Think Buffalo Bills :thumbsup:)
    Techoma and ARCHIVE[OP] like this.
  7. Jan 15, 2016 at 9:28 AM
    #47
    evan
    evan Well-Known Member
    SK, Canada
    FYI - The top setting on 5100's (part number 24-239370) is 2.5".
    Edit: My bad. Just reread your post. Yes, not maxed out is a little less than 2".
  8. Jan 15, 2016 at 9:32 AM
    #48
    imageomega
    Jarrod
    Ah, so its 1" (level) or 2.5" (max) and there is no setting between? Thats where I got the 2" from...
  9. Jan 15, 2016 at 9:33 AM
    #49
    evan
    SK, Canada
    Sorry, all I did was confuse the situation... There are four settings. 0, .85, 1.75 and 2.5.
    A block or cheap AAL would be cheaper but this looks like a much better option. I'm thinking about it. Do it! Be the guinea pig!
    Techoma likes this.
  10. Jan 15, 2016 at 9:35 AM
    #50
    imageomega
    Jarrod
    Ok, so you could use this product + 5100's and have somewhere around +1.25" (rear) and +1.75" (front). Reasonable.
    /end threadjack
  11. Jan 15, 2016 at 10:22 AM
    #51
    stihlfoursix_0
    stihlfoursix_0 Well-Known Member
    Idaho
    05 DC TRD OR
    sub...real nice work!
    ARCHIVE[OP] likes this.
  12. Jan 15, 2016 at 11:52 AM
    #52
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Thanks Chris for stepping up and giving this kit a shot, being among the first few, and for reporting back here about it, I look forward to the pictures.
    If I recall, you have the OME Dakars, correct?
    DCLBFTW[QUOTED] and Techoma like this.
  13. Jan 15, 2016 at 12:47 PM
    #53
    DCLBFTW
    Minnesota
    06 dclb
    Ome dakars with the d29xl add
    a leafs
  14. Jan 15, 2016 at 5:34 PM
    #54
    livnlrn
    livnlrn Well-Known Member
    Rick
    Elkton, Virginia
    2009 TRD double cab
  15. Jan 15, 2016 at 5:43 PM
    #55
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I like the looks of these hangers. In the spring/summer I plan to upgrade to Allpro Expo leafs and I'd love to do this shackle flip as well. I may drill some new holes in the shackles to get closer to stock shackle length. I'm worried about having too much lift in the rear with Expos and shackle flip.
  16. Jan 18, 2016 at 9:55 AM
    #56
    ARCHIVE
    Eric
    A better solution would be add-a-leaf or to remove a leaf from a Expo spring pack if you really wanted a shackle flip, and minimal lift. You'd be only reducing lift by .3" to get a stock length shackle, and you couldn't redrill my shackle without hitting the original hole
  17. Jan 18, 2016 at 11:37 AM
    #57
    weldo
    Pittsburgh, pa
    Thanks for the info! I do want to run a shackle flip because I like a performance gains. It's just tough to find the perfect leaf pack...
  18. Jan 18, 2016 at 11:47 AM
    #58
    ARCHIVE
    Eric
    You're welcome, does your truck have the TSB replacement 4 pack springs? I'd be more trusting of those updated springs with AAL than the early 3 pack crack prone ones
  19. Jan 18, 2016 at 11:52 AM
    #59
    weldo
    Pittsburgh, pa
    Yeah, mine has 3+1. And I actually have an add a leaf on them already. It was made by a local spring shop. It gave me like 4" of lift and rides kind of stiff. The AAL is a long, single heavy gauge leaf. I figured the Expo leaf pack would be a bit softer than my AAL but still allow me to carry all the extra weight I have.
  20. Jan 18, 2016 at 11:55 AM
    #60
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    Looks awesome.
