2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Jan 18, 2016 at 6:34 PM
    #61
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Thank you
  2. Jan 18, 2016 at 6:41 PM
    #62
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    Might have to order a set after I get my front end rebuilt and give them a try. Would like to get a little more droop out of the back.
  3. Jan 18, 2016 at 8:17 PM
    #63
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    uploadfromtaptalk1453176976164.jpguploadfromtaptalk1453176983556.jpguploadfromtaptalk1453176993713.jpguploadfromtaptalk1453177000166.jpguploadfromtaptalk1453177016077.jpguploadfromtaptalk1453177037434.jpg
    Pirhett, 14489 and Crom like this.
  4. Jan 18, 2016 at 11:22 PM
    #64
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    This ex-Buffalonian is going to need to buy a set soon....
  5. Jan 19, 2016 at 9:51 AM
    #65
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    Since you have both the relocation and flip whats your down travel look like on flat ground?
  6. Jan 20, 2016 at 4:52 PM
    #66
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I'll be purchasing one next week when I get my bonus!
  7. Jan 20, 2016 at 5:59 PM
    #67
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Is it the picture angle, or is the shackle going negative here? Your tire is still on the ground, so I'd venture to say you have more down travel than that. It would be a shame if the shackle inverted. I would move the hanger forward if that's an option.
    Crom, DCLBFTW[QUOTED] and HomerTaco like this.
  8. Jan 20, 2016 at 7:37 PM
    #68
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I was thinking the same. There's so many different factors to consider with this mod. I hope people do their research before taking this on.
    Pirhett, IronPeak, Crom and 1 other person like this.
  9. Jan 20, 2016 at 8:12 PM
    #69
    DCLBFTW
    Minnesota
    06 dclb
    Up travel is not as much as i would like and i was bottoming out my shocks before i was able to get the down travel fully extended
    I need to extend my timbrens
  10. Jan 20, 2016 at 8:20 PM
    #70
    ARCHIVE
    Eric
    The shackle won't invert the way DCLBFTW has it set up. The shackle is about vertical at near max droop.
    DCLBFTW, what position are the brackets in?
    Also, your uptravel is going to be limited by the springs when empty since you have an extra leaf which adds spring rate
  11. Jan 20, 2016 at 8:21 PM
    #71
    DCLBFTW
    Minnesota
    06 dclb
    Its in the forward position but i am going to change that to the rear position this weekend
  12. Jan 20, 2016 at 8:21 PM
    #72
    Usethe2nd
    Justin
    Fall city
    Welded metal
    wouldn't that lessen the angle at full droop?
    bobsuruncle likes this.
  13. Jan 20, 2016 at 8:24 PM
    #73
    DCLBFTW
    Minnesota
    06 dclb
    I think It will lessen the angle at ride height and it will be a greater angle at full droop ?
    But i could be wrong
  14. Jan 20, 2016 at 8:31 PM
    #74
    Usethe2nd
    Justin
    Fall city
    Welded metal
    it'd cause it to be more vertical at ride height and possibly "cam" over at full droop
  15. Jan 20, 2016 at 8:33 PM
    #75
    Usethe2nd
    Justin
    Fall city
    Welded metal
    my goal was to beat @bobsuruncle at the reply, regardless of how confusing it might have been
  16. Jan 20, 2016 at 8:34 PM
    #76
    DCLBFTW
    Minnesota
    06 dclb
    I guess it might now that i think about it more
    I think i am going to try it out and see if it works good
  17. Jan 20, 2016 at 8:36 PM
    #77
    ARCHIVE
    Eric
    I agree, I think the shackle angle is really good where it is. I don't like the shackles steep at normal ride height.
    Chris what's the travel on the shocks?
  18. Jan 20, 2016 at 8:37 PM
    #78
    SMKYTXN
    Nathan
    Houston
    DCFB
    So you have the mount in the position closer to the cab right now, and you're going to move it away from the cab?
  19. Jan 20, 2016 at 8:41 PM
    #79
    DCLBFTW
    Minnesota
    06 dclb
    Correct
  20. Jan 20, 2016 at 8:42 PM
    #80
    Usethe2nd
    Justin
    Fall city
    Welded metal
    incorrect actually :anonymous:
    ARCHIVE[OP], SMKYTXN and bobsuruncle like this.
