2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Mar 7, 2017 at 8:45 PM
    #821
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    *golden ticket* still havent used. Hoping to stack another one this year if thats allowed @HomerTaco ;)
    And Flloyd, i had to pay for the tickets:rofl:
  2. Mar 7, 2017 at 8:50 PM
    #822
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Pretty sure it's a gram that you don't have to wait for? :notsure:
    stairgod, fatfurious2 and Blackout14 like this.
  3. Mar 8, 2017 at 3:33 AM
    #823
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
  4. Mar 8, 2017 at 4:09 AM
    #824
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    OP is giving away a shackle flip on Instagram :thumbsup:
  5. Mar 8, 2017 at 4:24 AM
    #825
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
  6. Mar 8, 2017 at 6:11 AM
    #826
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    @Blackout14 oh you can have it. If it was up to me I'd pic you.
    Blackout14 likes this.
  7. Mar 8, 2017 at 6:26 AM
    #827
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Yeah I'm trying to double dip here. I've already got a flip kit, but I shared the IG post anyways. :D:D That new finish is looking good. Nothing to see here move along.
    Coot83 and Blackout14 like this.
  8. Mar 8, 2017 at 11:29 AM
    #828
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    I'm thinking it would just be smart business for Eric if I won, that way I would be forced to buy a shock relocation setup to go with it, haha
    Blackout14 and stairgod like this.
  9. Mar 8, 2017 at 5:07 PM
    #829
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Sorry for my laziness but what length brake lines are you guys running with the flip?
  10. Mar 8, 2017 at 5:20 PM
    #830
    fatfurious2
    David
    Ashburn, VA
    I have stock +5". But i didn't win the flip kit yet
    Maggot61 likes this.
  11. Mar 8, 2017 at 5:59 PM
    #831
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Shock length will be the determining factor as it is normally the limiting down travel factor. I went with +4 and will have a 26.17" fully extended shock. That is about 3" longer than the stock shock.
  12. Mar 16, 2017 at 7:15 AM
    #832
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    What length brake lines is everyone running with this? Will 24" work?
  13. Mar 16, 2017 at 7:27 AM
    #833
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Do you want me to measure mine? Think I got them from Wheelers
    I got the +4" lines from Wheelers. No clue what stock length is though.
    @HolyHandGrenade Jimmy, what length you running?
  14. Mar 16, 2017 at 7:33 AM
    #834
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    The shock should NOT be your limiting factor, unless you like blowing seals and buying new shocks. The springs SHOULD be limiting factor. If you are doing the shackle flip, you should measure everything without shocks attached and buy the correct length shocks. The B110 Bilstein recommended for the shackle flip should fit most peoples applications without overextending. Up travel will depend on tire size, and bump stops should be adjusted as to not compress shocks too far. Good thing is, billies have lifetime warranty and are about $100 a shock. can't even tell the difference between these and my $1500 king's other than the size of the shaft, ride feels the same.
    I have 24" which is pushing it fully extended/drooped on one side. I wish had just gotten longer and had plenty of extra.
  15. Mar 16, 2017 at 7:43 AM
    #835
    gottaToy
    JJ
    1985 Moped
    I lied! I have 24", which have been fine, but should have gone longer just in case. Would also need longer if you do a shock relocate and even more travel( I just have flip). Stock are 20" long according to archive garage.
  16. Mar 16, 2017 at 9:33 AM
    #836
    Glenn_R
    Glenn
    I agree that the shock should not be the limiting factor, but from what I have read on this site and even measured on my stock setup prior to modify, the shocks are the limiting factor. Most people seem to be buying shocks that are around 9-10" of travel with after market springs and IMO the shocks are limiting down travel of those springs. I would also say that most that are running a 14-14.5" compressed shock length and are wasting travel because with the stock BS on a 2016-2017 you are not going to compress passed the 15" mark because of the factory bump stop (the spring would also be severely inverted. I measured my setup and is 15.75" at fully compressed bump stop (Timbren) and max droop without shock is 25"(foot pushing it down). My setup is close but still more than likely shock limited because of forced articulation and the shock being outboard of the springs. This is running BDS Fox 2.0s that are 15.55" compressed and 26'' extended. I picked this shock because of the 10.5" of travel and where the travel is. Stock Springs with Wheeler AAL and Archive shackle flip. When/if I do the shock relocate and springs that have more droop my +4" brake lines are hopefully long enough.
  17. Mar 16, 2017 at 9:56 AM
    #837
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I got shackle flip and relocate. Use all 12" of my shock travel, and +4" lines are long enough at full droop. I did mod my ABS wire bracket because that was tight at full droop.
  18. Mar 16, 2017 at 10:10 AM
    #838
    Glenn_R
    Glenn
    Do you have a build thread that talks about your rear suspension setup? Would like to know what relocation kit, wheel BS, spacers, springs, shocks, and any other pertinent data. And how you like it and what would you do different?
  19. Mar 16, 2017 at 10:15 AM
    #839
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    No build thread as yet. Too damn busy working on the truck to do one. If I could do it all over again, I would have gone SUA and done 16" shocks through the bed right from the get go.
  20. Mar 17, 2017 at 4:56 AM
    #840
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    I have stock springs with the wheeler aal as well and have been wanting to do the shackle flip and longer shocks next. Do you find the rear too soft? Have you wheeled much/ run into axle wrap with that setup? Mine have about 30k miles on them and it seems like the springs are nearly flat and I get alot of wrap as is. Just curious.
