2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Mar 17, 2017 at 5:27 AM
    #841
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    I'm thinking I'll be okay then
  2. Mar 17, 2017 at 6:44 AM
    #842
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    For me this setup is an interim solution until I buy a complete leaf pack and do the shock relocate. The shackle flip gives you more droop and IMO will require new shocks and bump stops that meet the new suspension travel. I don't think it is too soft but I want flex and wont be hauling anything other than gear. I don't notice axle wrap but you can feel a difference with the shackles flipped. when you leave a stop sign you can feel the as sink a little. I think they allow the springs to move easer.
    Redsyota[QUOTED] likes this.
  3. Mar 17, 2017 at 8:12 AM
    #843
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Keep your eyes peeled for a new thread in Suspension. I believe it will be an enlightening experience in the old debate of stock shackles vs flip.
    Blackout14, Coot83 and bobsuruncle like this.
  4. Mar 17, 2017 at 8:26 AM
    #844
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Will it be from jberry? He seems to really like going against everything TW, and a lot of it is true. Although, if you have the money and means to do fabrication, that's in a different league from most of us.
  5. Mar 17, 2017 at 9:36 AM
    #845
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    No, it will be from me. I had my own theory, and devised an experiment, and will reveal my results. I am sure many will be surprised by the results.
    Dogg23, bobsuruncle and seoulja99 like this.
  6. Mar 17, 2017 at 9:43 AM
    #846
    Glenn_R
    Glenn
    I did some before and after measurements with stock springs myself. Cant wait to see what you found to compare to what I found on a 2017.
  7. Mar 17, 2017 at 12:55 PM
    #847
    gottaToy
    JJ
    1985 Moped
    I can tell you my measurements were about the same. I'm guessing by the numbers you posted, you measured the droop without shocks with both back wheels off the ground, because they would be the same as I got @26". However, when one side is stuffed and the other at full droop, I'm about 27 1/2-28". I must run a bigger tire, so my bumps are taller and my compressed is greater than yours?
  8. Mar 17, 2017 at 5:14 PM
    #848
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    @ARCHIVE,
    I bought and received your shackle flip kit for my 2012 TX Baja edition Tacoma which came with the TRD Bilstein 5160 rear shocks with reservoirs. I really want to install it as soon as possible, but my concern is blowing out my existing rear suspension system.
    From what I have gathered, the TRD Bilstein 5160's are approximately 13.8" compressed and 23.2" extended; which is approx. 9.4" of travel. I say "approximately" because I have also read that these particular 5160's have 10" of travel.
    I also currently have the AllPro Standard spring leaf packs, AllPro U-bolt flip kit, Timbren Bumpstops, and the AllPro extended brake lines.
    Questions:
    1. Would you know if the current Bilstein 5160's are the limiting factor of travel for my rear suspension?
    2. Will I be able to install your shackle flip kit without damaging my 5160 shocks in my current set up?
    3. If I absolutely have to change out my rear shocks, what length shocks would you recommend with your shackle flip kit and the AllPro Standard spring leaf packs?
    4. Is a shock relocation kit recommended or required with your shackle flip kit?
    TIA for your time and look forward to your answers.
  9. Mar 17, 2017 at 5:55 PM
    #849
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    1) Every truck is different, therefore you would have to install the kit and measure to find out how much travel you have and compare it to the specs for your shocks.
    2) Yes, so long as you stay within the specifications of your shocks (example: I have 5125's installed. I can easily install the kit, however most likely will not be able to use it to its full potential).
    3) Refer to answer number 1.
    4) No, however, it is recommended to achieve the maximum allowable droop for your setup.
    I have absolutely no affiliation with Archive or the design of his product with the exception of purchasing it, however I did stay at a Holiday Inn Suites
  10. Mar 17, 2017 at 6:10 PM
    #850
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Anyone have a picture with these installed? Also, can these go on a stock 2011 Off-Road without issues. I'll take the 1.5 of lift. Previous owner put tiny 1-inch spacers in the front, too. Meh.
  11. Mar 17, 2017 at 7:14 PM
    #851
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Tacoma stock height has the shocks extended to ~19". So if you have 3" springs and then 1" from flip, you'll need longer shocks. You can look at the Bilstein B110s but they are 16.4" compressed so you may need to space your bumps to prevent bottoming, but you do have Timbrens. They are 27" extended
    seoulja99[QUOTED] likes this.
  12. Mar 18, 2017 at 6:58 AM
    #852
    HoosierTaco06
    HoosierTaco06 Well-Known Member
    Jeff
    Northwest Indiana
    2006 Tacoma TRD Off-Road
    Locker anytime, ABS killswitch
    Here is a picture of mine on an 06 with B110's and a 3-leaf add a leaf. If that is what you where looking for.
    ARCHIVE[OP] likes this.
  13. Mar 18, 2017 at 7:00 AM
    #853
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    No u bolt flip?:annoyed:
  14. Mar 18, 2017 at 7:17 AM
    #854
    HoosierTaco06
    Jeff
    Northwest Indiana
    Not yet. On the list to get done.
    stairgod likes this.
  15. Mar 18, 2017 at 7:18 AM
    #855
    HoosierTaco06
    Jeff
    Northwest Indiana
    Damn I really need to repaint my axle...
    bobsuruncle and stairgod like this.
  16. Mar 27, 2017 at 3:19 PM
    #856
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    :notsure:
    RacecarGuy, paranoid56 and adanfon like this.
  17. Mar 28, 2017 at 3:16 AM
    #857
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Got busy. Coming soon. I will tag you.
    bobsuruncle[QUOTED] likes this.
  18. Mar 28, 2017 at 6:02 AM
    #858
    Glenn_R
    Glenn
    Tag me please, very interested.
  19. Mar 28, 2017 at 3:53 PM
    #859
    gottaToy
    JJ
    1985 Moped
    C'mon man, the suspense is killing me!
  20. Mar 28, 2017 at 8:21 PM
    #860
    Rusty15Tacoma
    Rusty
    San Diego
    Also interested
    stairgod[QUOTED] likes this.
