2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Jan 20, 2016 at 8:43 PM
    #81
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    Alright i just ran out to the truch and you are right
  2. Jan 20, 2016 at 8:45 PM
    #82
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Haha, I need to know, the brackets are in rearmost position (forward holes)?
  3. Jan 20, 2016 at 8:45 PM
    #83
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    subbed, badass
  4. Jan 20, 2016 at 8:48 PM
    #84
    DCLBFTW
    Minnesota
    06 dclb
    Im in the rear holes
    Techoma and ARCHIVE[QUOTED][OP] like this.
  5. Jan 20, 2016 at 9:04 PM
    #85
    ARCHIVE
    Eric
    Ok, then I suggest leaving the brackets where they are. If that's full droop on those long travel shocks, then I'm happy with the shackle angle
  6. Jan 20, 2016 at 9:05 PM
    #86
    DCLBFTW
    Minnesota
    06 dclb
    Its not full droop i need to extend my bumps so i dont over compress my shocks
  7. Jan 20, 2016 at 10:31 PM
    #87
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Any pics of this installed? Does this allow you to mount any where on the frame? Reason I ask I have some longer deavers I wanna put in the truck from a full size truck
    ARCHIVE[OP] likes this.
  8. Jan 21, 2016 at 3:24 AM
    #88
    ARCHIVE
    Eric
    Oh on the opposite side that's compressing, I got it now. So are you wanting to lower the shock mounts on the axle to allow more up travel? Hitting full droop as it sits now should be good test for shackle angle
  9. Jan 21, 2016 at 3:32 AM
    #89
    ARCHIVE
    Eric
    See post #29. The brackets are designed to use factory rivet holes to bolt in. But the brackets can slide down the frame and you match drill new holes, but a few things:
    -My brackets are 2.375" (60mm) wide like Taco/Tundra springs
    -The frame is tapered so the brackets get closer the farther back you go, should be fine 2 inches back
    -you will run into bumper mounting holes if you are using those.
    Edit: What vehicle are the springs from? Here is a site you can check spring center pin spacing.
    Tundra 28.56F/31.88R http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=7670
    Tacoma 27.69F/27.69R http://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=17956
  10. Jan 21, 2016 at 4:20 AM
    #90
    basically_stock_
    basically_stock_ 3rd Shift Lurker
    Eric
    Iowa
    2009 TRD Sport, Free & Clear
    2" lift, SCS Ray 10, Falken Wildpeak's
    Looks like something i may be interested in after some more reasearch on my part. Nice looking product.
  11. Jan 21, 2016 at 5:21 AM
    #91
    ARCHIVE
    Eric
    Thank you Eric
  12. Jan 21, 2016 at 8:20 AM
    #92
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    I didn't read the whole thread so I apologize but they came off a long traveled fully caged ranger but have been told they are f150 deavers. I know I can cut my current mount and re weld just figured this might be a good alternative and much stronger than stock? Thank you for your replies. I'd love to get this just want to make sure I can use it for my application
  13. Jan 21, 2016 at 9:06 AM
    #93
    kevin.95
    kevin.95 Well-Known Member
    Kevin
    Kennesaw, GA
    09 DCSB Sport 4x4
    Bilstein 5100's, Tint, Skids, Speakers, OEM Roof Rack, Westin Brush Guard, HID Offroad lights, Fog Light Anytime Mod, Stealth Customs Matte Gunmetal w/ Kenda MT's, Relentless Fab Bed Bars w/ yakima cargo rack
    i like this, subbing
  14. Jan 21, 2016 at 5:47 PM
    #94
    ARCHIVE
    Eric
    These brackets are thicker than stock, and have less force on them. The F-150 springs should be 2.5" wide, but the bushings may be 2.875 wide like the Toyota's and these brackets
  15. Jan 21, 2016 at 7:09 PM
    #95
    DCLBFTW
    Minnesota
    06 dclb
    I am getting more pics tonight of the shackle angle i just extended my bumps so i will try to get full droop
  16. Jan 21, 2016 at 7:32 PM
    #96
    ARCHIVE
    Eric
    Thanks Chris
  17. Jan 21, 2016 at 7:54 PM
    #97
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    So these will work for my needs then correct?
  18. Jan 22, 2016 at 7:46 AM
    #98
    ARCHIVE
    Eric
    I can't say yes or no, you're looking at changing every dimension of the spring. It's probably doable, but too many variables for me to say yes to that
  19. Jan 22, 2016 at 9:09 AM
    #99
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    :thumbsup::rofl::D:cheers::censored:
  20. Jan 22, 2016 at 10:40 AM
    #100
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Thanks for the response I'm going to hack my current ones reweld them on the frame and do it that way of I find the stock ones are too lame I will buy yours and make them work which will probably happen at some point
