2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Oct 16, 2017 at 7:18 PM
    #1141
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Should be a good fit with pretty good travel like Deaver U402's I'm estimating 12-14" shock travel
    seoulja99 and 90yota[QUOTED] like this.
  2. Oct 16, 2017 at 7:20 PM
    #1142
    Manwithoutaplan
    ID
  3. Oct 17, 2017 at 1:36 AM
    #1143
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I think at this point I would have to see a legit diagram of what ou are talking about. Is this what you were thinking could be an LT substitute back in the LT BS thread where you remove the rear shackle without relocating the front shackle as well?
  4. Oct 17, 2017 at 1:55 AM
    #1144
    ARCHIVE
    Eric
    Yes, that's the new Archive hanger I'm talking about. I do believe that it could be honestly called LT if it was moved back and you stretched an SUA spring back to match.
    The DMZ shackle hanger is just as dependent on the springs it attaches to so that it can be "long travel."
    But no this will not be capable of as much as DMZ hanger, can't fit that long of a shackle under the frame rail reasonably
  5. Oct 17, 2017 at 4:18 AM
    #1145
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Is there an exact spring under leaf that this was designed to work with? I get the impression if it were that simple to just adjust the rear shackle hanger only that LT kits would likely do this. From the ones I have seen, they have to move both the front and rear shackle locations out wider than stock to accommodate the bigger LT sua springs.
  6. Oct 17, 2017 at 4:28 AM
    #1146
    ARCHIVE
    Eric
    Did you know that the DMZ springs are almost the same length as stock from front hanger to center pin, but longer at back?
    I think the biggest reason he makes front hangers was to move springs towards tires so the shackle could swing next to frame rail instead of under.
    I'm making a kit for the masses, who want increased performance and quality, without all the fab work and big $$$ install bill.
    Eric
    seoulja99 likes this.
  7. Oct 17, 2017 at 4:33 AM
    #1147
    Coot83
    Scottsdale, Az
    2012 Baja TX
    But its not just DMZ...Giant relocates both, as well as camburg. Those are the current Tacoma LT kits I am familiar with, but Im sure there are others out there as well. Giant's is completely bolt on to the stock shackle hanger locations and DMZ is in the process of making a bolt on version of his kit. I think if they could just extend the hanger without enlarging the geo then they would have done it. Either way I should be able to speak more intelligently in a few months when I get my kit on the rear in regards to this topic.
  8. Oct 17, 2017 at 4:46 AM
    #1148
    ARCHIVE
    Eric
    True, because they all have shackle moved out to swing next to frame rail like the full size trucks come stock. Mine is staying under to work with stock front hanger/perch for all the spring over overland rigs, trail rigs and mid travel SUA folks, and because not everyone needs 16"+ travel.
    Please share your build experience here, and if you have springs already measure them up and let us know what you got.
    I'm totally fine calling it mid travel, just got influenced by the many calling TC front long arms "long travel"
    Thanks, Eric
  9. Oct 19, 2017 at 6:54 PM
    #1149
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    We need more pictures, please.
  10. Oct 19, 2017 at 7:06 PM
    #1150
    ARCHIVE
    Eric
    Sorry David and everybody, the production tweaks are almost done, but I'm gonna stick with my schedule.
    November release! Thanks for your patience!
    Maggot61 and seoulja99 like this.
  11. Oct 21, 2017 at 10:14 PM
    #1151
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Yes they will. I had to crank my icons up to full 3" just somewhat make the lift look normal. When I'm fully loaded with rtt and camping gear it sits level. Unloaded it's close to 1/2" higher in the rear after the springs broke in and suspension settled. I'm running normal dakars and this flip on my 06 dcsb.
  12. Oct 21, 2017 at 10:16 PM
    #1152
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Did the leaf pack invert? If so it's not the shackles fault, you need better bump stops.
  13. Oct 22, 2017 at 9:18 AM
    #1153
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    My front's are maxed out at 3". I wouldn't mind more lift in the rear, but it already sits raked as is. When it's loaded down with the RTT, camping crap, Hi-lift, full spare, fire wood etc. it sits nice and level. Plus, I don't think my rear shocks have the extended length that they recommend for the shackle.
  14. Oct 27, 2017 at 8:40 AM
    #1154
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    @ARCHIVE have my new deaver U402 expedition stage III on the way. I have the mounts back right now with the stock springs and wheeler single AD. Do you know a good starting place for the U402s? running 10" shocks and timbren bumps. Will get the shock relocate kit later this year I hope.
  15. Oct 27, 2017 at 8:44 AM
    #1155
    ARCHIVE
    Eric
    @Glenn_R Good choice on Deaver. For the shackle flip, I would start with the rearmost position which should put shackle angle about 30 degrees from vertical. It sounds like that's where the brackets are currently.
    Eric
  16. Oct 27, 2017 at 9:38 AM
    #1156
    Glenn_R
    Glenn
    I cant remember for sure but know I did drill a hole.
  17. Oct 27, 2017 at 9:44 AM
    #1157
    ARCHIVE
    Eric
    Ok, that's the foremost position, you can try it but shackle angle would be closer to 45deg. I'd recommend moving them rearward, using all 4 factory holes.
    Eric
  18. Oct 27, 2017 at 9:45 AM
    #1158
    Glenn_R
    Glenn
    Thanks Eric
    ARCHIVE[OP] likes this.
  19. Nov 1, 2017 at 6:11 AM
    #1159
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    :cookiemonster:
    ARCHIVE[QUOTED][OP] and TACOVRD like this.
  20. Nov 1, 2017 at 6:25 AM
    #1160
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
