2005 - 2023 Archive Garage Premium Shackle Flip Lift Kit
Discussion in 'Archive Garage' started by ARCHIVE, Nov 30, 2015.
  1. Feb 15, 2016 at 8:11 AM
    #121
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Interested for the future
  2. Feb 15, 2016 at 5:20 PM
    #122
    TXGnftr
    TXGnftr Well-Known Member
    Texas
    These in the shelf ready to ship? Couldn't quite tell...
  3. Feb 15, 2016 at 5:25 PM
    #123
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I just got my new batch of steel parts today. I'm gonna need up to 2 weeks to ship, probably will be painted black though, not zinc-nickel plated
  4. Feb 15, 2016 at 5:28 PM
    #124
    TXGnftr
    Texas
    No issue on black painted...on travel till Thursday and will contact for a set when back in TX. Appreciate quick reply.
    ARCHIVE[QUOTED][OP] likes this.
  5. Feb 15, 2016 at 5:31 PM
    #125
    ARCHIVE
    Eric
    Thanks, sounds good
  6. Feb 22, 2016 at 7:52 PM
    #126
    ARCHIVE
    Eric
    Ok, so I have begun to do some welding on the next batch and I wanted to show you how revision 2 ended up looking, (compare post #102). These will now fit without massaging if you have or eventually buy a Pelfreybilt or AllproOffroad rear bumper. CBIoffroad and Trailgear bumpers are no problem either, they even fit with the previous design.
    My brackets now fit within the space of the stock hanger for BOTH mounting positions. I want it so no one has to modify their brackets or bumper. There is only 1 extra step for the foremost position. Since the rear upper corner now only has 1 hole, simply match drill one 1/2" hole per bracket after the brackets are moved forward and bolted in the other 3 holes.
    Crom, bobsuruncle, mattraptor and 2 others like this.
  7. Mar 6, 2016 at 12:39 PM
    #127
    ARCHIVE
    Eric
    Here are some fresh pics of the current kit. In addition to the revised brackets, the stainless shackles are staying as a feature, and now have an improved hourglass shape for looks.
    mcharfauros, 14489, Crom and 9 others like this.
  8. Mar 17, 2016 at 3:32 AM
    #128
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    Those are looking good. I'll hit you up when I'm ready to do this.
    ARCHIVE[OP] likes this.
  9. Mar 17, 2016 at 11:59 AM
    #129
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Ordering one, a pair, now.
    ARCHIVE[OP] and utroda like this.
  10. Mar 17, 2016 at 12:02 PM
    #130
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    @ARCHIVE Is there any reason the shackles you provide with this kit are a "two piece" and not a gusseted one piece shackle? Seems like the two piece shackle would have more lateral movement.
  11. Mar 17, 2016 at 1:07 PM
    #131
    Tacoma SS
    Denver
  12. Mar 17, 2016 at 1:10 PM
    #132
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I'm :jellydance: this came out AFTER I already had mine waiting to be installed...
  13. Mar 17, 2016 at 1:11 PM
    #133
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    you'll really like it :thumbsup:
  14. Mar 17, 2016 at 1:13 PM
    #134
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Did you leave yours just bolted? Or put some welds on?
  15. Mar 17, 2016 at 1:17 PM
    #135
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Bolt on for now, because i'm still working on things... I'm not sure if I would weld it or not, I like that I have the option to adjust, which is nice if I consider going to a 63 swap down the road. Thats also why I like the 2 piece shackle you can also make one to fit your application needs.
    ARCHIVE[OP] and bobsuruncle like this.
  16. Mar 19, 2016 at 3:53 PM
    #136
    ARCHIVE
    Eric
    The high strength bolts are more than adequate for holding it to the frame on the Tacoma, and the Tacoma is cool in that it has the flange under the frame to support the load, plus the bolts allow you to make use of the adjustment :thumbsup:
  17. Mar 19, 2016 at 4:02 PM
    #137
    ARCHIVE
    Eric
    Thank you Robert!
    Good question, I have the same design on my 3/4 ton that has had 3,000 lbs of dirt in it, without feeling flexy, so I am confident the seperate shackles on the Tacoma will be fine. These shackles are 4", but any longer than 5" I would add a brace in between the 2 shackles
  18. Mar 23, 2016 at 5:20 PM
    #138
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Looking good
    ARCHIVE[OP] and scottalot like this.
  19. Mar 23, 2016 at 5:23 PM
    #139
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Leave me alone and quit following me :rofl:
    scottalot[QUOTED] likes this.
  20. Mar 23, 2016 at 5:27 PM
    #140
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Trying to figure out which one I want to go with haha. Still learning a lot of stuff about them
