2005 ac issue??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by petcotaco, Jun 12, 2022.
  1. Jun 12, 2022 at 3:12 PM
    petcotaco
    petcotaco [OP] Member
    Dan
    2005 Tacoma TRD sport short bed
    K&N air filter, are bed cover
  2. Jun 12, 2022 at 4:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the IG1 NO2 Fuse.
    MG CLT Relay.
    TnShooter likes this.
  3. Jun 12, 2022 at 4:40 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Also check belt tension and age and your spring tensioner idler.
    If the tensioner idler is "vibrating" when the truck is running it's time to replace it, it should be pretty steady in it's position at idle.
    Hard to give you an idea of force but it should require somewhere around 30-40 ft lbs to get it to slack off.
    The flashing light can be an indicator that the free wheeling clutch is not locking up or that the belt is slipping on the pulley.
    Jimmyh likes this.
  4. Jun 12, 2022 at 5:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    With the A/C controls turned on, check for power right at the magnetic clutch connector. If it's got power is should be engaged and turning
    Jimmyh likes this.
