2005 and early 2nd-gen issues -- and how to fix them!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mk5, Sep 5, 2021.
  1. Sep 6, 2021 at 4:03 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I think these problems only v6 mainly
  2. Sep 6, 2021 at 4:09 PM
    Oreo Cat
    mine blew right after 200k, I kept just topping the radiator off and taking the extra coolant out of the reservoir every 30-45 minutes of driving and it did that for a while. right after that my frame failed at the mount.
    mk5[QUOTED][OP] likes this.
  3. Sep 6, 2021 at 4:10 PM
    Oreo Cat
    can't say id recommend an 05/06 v6.
    mk5[OP] likes this.
  4. Sep 6, 2021 at 7:23 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    I checked the door jam it says June 06 so I guess I'm good? Thanks for the info everyone
    mk5[OP] likes this.
  5. Sep 6, 2021 at 7:56 PM
    mk5
    mk5 [OP] Asshat who reads books
    SoCal
    '05 access cab 4x3
    Yes, definitely, my summary is written from the perspective of an 05 V6 4x4 owner, although I'll strive to consolidate issues with other early 2nd gen models and options here as well!
    Sounds like you made if further than many of us! But sorry to hear about the frame failure, I guess it was it out of warranty?
    As the frame replacement window continues to shrink, eventually excluding all years of 2nd gen production, I'm afraid this is the fate facing many otherwise functional trucks across the vast swaths of our continent where it snows.
    Personally, I would recommend replacing the head gaskets well before daily coolant top-off is necessary, but if your truck's frame is on borrowed time... well, it sounds like you made the right call there!
    As a happy '05 owner, I respectfully disagree, but your experience definitely highlights the deficiencies of this model year. It takes proactive and reactive maintainence to keep these trucks on the road, and I'm hoping this thread helps reduce the occurrence of people caught off-guard by these problems.
    Sounds like it, and I sure hope so! Make sure to check your engine mounts and consider reinforcing them when convenient, and keep an eye on the transmission cross member too. Hope to see you on the trail someday.
  6. Sep 6, 2021 at 8:06 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I have a 2005 that had the Head Gasket issue around 137,000 miles. I had it fixed. I now have 247,000 miles and I will have this 2005 until the Doors and Fenders fall off of it. If you are afraid of vehicle troubles you better buy a Good Pair Of Shoes because there isn't one out there that isn't going to have any issues. I don't care of the Year or Manufacture they all of Good Ones and Bad Ones.
    mk5[OP] likes this.
  7. Sep 6, 2021 at 8:12 PM
    DG92071
    DG92071 Well-Known Member
    There's a thread on TW asking 2005 owners if the head gaskets had failed. Like EVERYTHING else on the internet the issue is highly exaggerated including in this thread.
    R0dzilla75 and mk5[OP] like this.
  8. Sep 6, 2021 at 8:26 PM
    Oreo Cat
    The dealers near me wouldn’t cover my frame (Colorado Springs at the time) but I was able to find a local shop to repair the frame for $500. Would’ve costed me more to have it towed somewhere where I could get it replaced.
    Looking back I wish I could’ve had the frame replaced but I was in a pinch and there’s no rust on the frame just the broken motor mount area
  9. Sep 7, 2021 at 10:11 PM
    HV101
    HV101 Well-Known Member
    Harlow
    2016 Gray Tacoma SR5 Access Cab
    None
    D83BC9B1-BA98-4661-994A-AA9D897CA41B.jpg We have a 2005 AC 4x4 OR MT with over 230k. This is a working truck hauling 300 gallons of H2O on steep dirt roads daily (CA drought ) It’s needed some front end work and rear differential rebuild but it’s a strong truck with original V6. Maybe we were lucky but I don’t see the problem.
    mk5[OP] likes this.
  10. Sep 8, 2021 at 12:40 AM
    surfjones
    surfjones Active Member
    Casey
    Houston
    05 DCLB Sport 4x4
    My head gasket failed on my 05 but with 398k on it. First noticed the coolant bubbling on Black gap trail in Big Bend NP of all places, held up for a few months after that. Replaced the engine with an 09 that had 90k. Frame was replaced around 250k miles under the recall.
  11. Sep 8, 2021 at 3:37 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Thanks for the post -- this is a good resource I'll hold onto in case I do come across any of these issues. I'm at 177k with no HG or other issues. Slow wheeling and a fair amount of time driving up / down the padre seashore. So far so good. I'm also in a very early one manufactured in Sept 04 that I drove off the lot in Dec 04.
  12. Nov 7, 2021 at 7:58 PM
    Charged Tacoma
    Charged Tacoma Member
    Justin
    Iowa
    05 TRD Sport Supercharged
    TRD Supercharger, 3" Toy Tech Lift, Wheels, Tires, Step up bars, Exhaust
    Nicely put together sir! I have never really understood the 05 stigma honestly. I have had my 2005 for close to 10 years and I have had several friends with 05’s as well. We have all found the typical “tough as nails” Tacoma reputation to be true !
    dk_crew and mk5[OP] like this.
  13. Mar 19, 2024 at 10:30 PM
    Jonny_09_taco
    Jonny_09_taco Well-Known Member
    Jonathan
    2009 grey Tacoma off-road
    Prinsu roof rack Baja Ditch lights
    I know this is probably an old tread but on my 06 Tacoma 2.7 there was a plastic hose that was leaking refrigerant and I found out is really common for those years cause in the new tacomas 07 and up is not a plastic hose but a metal one
    mk5[OP] likes this.
  14. Mar 21, 2024 at 11:20 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    2005 TRD Sport 147k miles and no signs of HG failure. Just chiming in.
    mk5[OP] likes this.
  15. Mar 21, 2024 at 7:22 PM
    #35
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I just saw this and am laughing because i'm a few posts up noting no issues back in 2021. I now have over 200k ... but did replace my HG at 190 - the common spot between cyls 4 and 6 - about a year ago. All in all, I'm glad I did. Truck runs great. And as the original owner I plan to continue to maintain it and driving it indefinitly.
    mk5[OP], JDTRD01 and XSplicer62 like this.
  16. Mar 24, 2024 at 6:42 AM
    #36
    cshinn89
    cshinn89 Active Member
    PA
    23 Tacoma Off Road 6 speed MT 05 Tacoma Off Road 6 speed MT
    i have an 05 v6 that has spent it's whole life in NJ/PA so rust is always an issue. no major problems, ive owned it since 08 and bought it with ~20k miles.
    frame replaced under frame recall in 2015 at ~135k Miles
    Rack and pinion rotted out and replaced later in 2015 at 150k Miles
    alternator replaced numerous times but the first time i replaced it i got a unit with a lifetime warranty.
    obvious wear items over time shocks, tie rods etc
    replaced power steering lines due to rust 2x
    all wheel bearings have been replaced at least once
    no major issues overall, power train is still all original
    no HG issues and sitting at ~240k miles today and prepping to sell the truck since i have a 2023 now. i still like the 05 better though
    -Chris
    JDTRD01, mk5[OP] and R0dzilla75 like this.
  17. Jun 12, 2024 at 2:41 PM
    #37
    Pjerdan
    Pjerdan “I do what I want”
    Philip
    Hebron KY
    2012 Tacoma 4x4 double cab (SR5 unfortunately)
    Working on it
    I loved my 05 TRD off road till I got my 2012, both have been great
  18. Jul 3, 2025 at 9:40 AM
    #38
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I guess you can call this a HG experiment. My 05 has 157K with no HG failure as of yet. I am replacing the coolant every 20-25,000 miles to keep the chemistry in the fresh stuff as "fresh" as possible. I don't know if that has much or anything to do with extending the life of a HG, but I do know it can't hurt anything other than my pocket book. Only time will tell.
