2005 Bulletproof Taco: 1 Ton SAC
Discussion in 'Solid Axle Suspension' started by NwiTACO, Jun 6, 2012.
  1. Mar 4, 2013 at 1:55 PM
    #301
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Ah. 35 spline?
  2. Mar 4, 2013 at 1:59 PM
    #302
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    No FJ Case :cool:?
  3. Mar 4, 2013 at 3:13 PM
    #303
    NwiTACO
    NwiTACO [OP] Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Nah...not for now. Who needs 2WD low anyways, and I have never had an issue with my electronic actuator anyways.
    The main reson I am going duals now is bc I only want to modify my driveshafts once. If I added the duals later I would be getting driveshafts modified now and again then.
    If I go with an FJ case down the road its the same dimensions as my taco case so all will be good.:cool:
  4. Mar 4, 2013 at 3:16 PM
    #304
    theduck911
    Max
    Locked and Geared!
    Figured you would have your reasoning for it:thumbsup:
    I've only had issue with mine once or twice. Once it dries out it seems to work fine.
    FJ Case & Crawler are on the list down the line tho :cool:
  5. Mar 4, 2013 at 3:16 PM
    #305
    BradyT88
    BradyT88 Well-Known Member
    Agreed. Plus you can get 2Lo with a simple little switch. I have it, but it is the byproduct of a VCS killswitch I rigged up. The FJcase is supposed to be a little stronger but I see no reason in upgrading to it until I kill my Taco case, or have more money than I know what to do with. haha
  6. Mar 4, 2013 at 5:58 PM
    #306
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I can't think of a time I would use 2lo.
  7. Mar 4, 2013 at 6:02 PM
    #307
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    steep decline with sharp switchbacks where turning would be improved with 2wd?
    about all i can think of
  8. Mar 4, 2013 at 6:11 PM
    #308
    BradyT88
    Yeah. I was thinking that may be useful for the Morrison Jeep Trail. Could save my tranny temps, or your clutch if you are a manual. That is assuming I have enough traction to do it in 2wd.
    It is also good for doing some donuts:p 2Lo can get your tires spinning pretty damn good! haha
    But yeah... pretty much useless... Like I said I have a benefit that switch as a VCS killswitch mostly:D
  9. Mar 4, 2013 at 6:43 PM
    #309
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Hopefully not. I plan on another solution to this issue...stay tuned.
    And I will have 2WD low just not 2WD compound low :D
  10. Mar 4, 2013 at 6:49 PM
    #310
    BradyT88
    True! That was one of my other arguments against an FJ case with a crawlbox. Forgot about it though. haha
    What is strapping the actuator?
  11. Mar 4, 2013 at 7:01 PM
    #311
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    The stock transfer case wont shift into low unless contacts are made in the ADD actuator...so some have strapped the actuator to the framerail to allow these contacts to be made still. I think I can come up with a better solution.:cool:
  12. Mar 4, 2013 at 7:20 PM
    #312
    BradyT88
    My 2Lo switch I have is an actuator bypass. It tricks the ECU into thinking that the ADD is engaged and the Tcase will shift into 4Hi and 4Lo, but I am essentially in 2wd since the disengaged ADD and basically absorbs all the power from the diff. Would this work for you? Or is the issue just with detecting the ADD in general or what?
  13. Mar 4, 2013 at 7:41 PM
    #313
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    The FJ's that have a standard transmission are full time 4x4. If you swap a FJ t-case into a standard transmission Tacoma, does it magically become full time 4x4 also?
  14. Mar 4, 2013 at 7:44 PM
    #314
    theduck911
    Max
    Locked and Geared!
    No. You can only swap in the T-Cases from the Automatics. See Wyatt's thread to learn everything you need to know about the subject :cool:
  15. Mar 4, 2013 at 9:59 PM
    #315
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    After cutting off the shift fork and sealing it up. :D
  16. Mar 5, 2013 at 5:25 AM
    #316
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Yeah I really dont think it should be too difficult to trick the 4wd ECU. I will be in touch for sure when the time comes. Thanks!
    Its being built using the Total Spline 23 spline inout from Marlin. Although they have never had a failed TrailGear 23 spline input I had them upgrade anyways.
    Last resort if I wanna get done quicker I may pull the fork and make a blocking plate to seal up the ADD unit and tackle the wiring later, but it would be nice to sell the (2) ADD actuators I currently have :D
  17. Mar 5, 2013 at 4:07 PM
    #317
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Ah yeah I forgot about the difference between gear and chain thanks for correcting me. Overkill? Maybe but it would go with the theme of this build (not meant as an insult :D).
  18. Mar 6, 2013 at 5:15 AM
    #318
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Theres no such thing as overkill. :D
  19. Mar 6, 2013 at 10:08 AM
    #319
    theduck911
    Max
    Locked and Geared!
    This :p
  20. Mar 6, 2013 at 6:12 PM
    #320
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    This build sucks
