2005 Front Differential Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by martymartw, Oct 10, 2009.
  1. Oct 10, 2009 at 1:02 PM
    martymartw
    martymartw [OP] New Member
    Marty
    Colorado
    TRD Sport
    3" Lift, Rock Sliders, Oversize Tires
    :confused: I have a 05 Tacoma with a 3" lift. The truck is making noise around 35-45 mph. Further investigation: I put the truck on jack stands and decided to spin the tires to isolate the problem. The outcome is as follows. Front driver wheel makes a clicking noise around the axle assembly when spun. The passenger tire does not. Any thoughts from people out there. I suspect something internal of the front differential is the issue. When the truck is shift into 4 Hi the noise goes away. In 2 Hi the noise returns.
  2. Oct 10, 2009 at 1:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    It could be your CV's.....How do they look?
  3. Oct 10, 2009 at 1:19 PM
    martymartw
    Marty
    Colorado
    TRD Sport
    CV's look great. There is a bit of an angle to them. I did install the differential drop kit thought. This noise is definitely a clicking noise between the frount left wheel and front differential. The right side makes no noise. I've been looking for a detailed view of the whole front drive assembly but can't find one.
