2005 PreRunner V-Belt Squealing
Discussion in 'Technical Chat' started by RobLewis, Apr 7, 2010.
  1. Apr 7, 2010 at 10:32 AM
    RobLewis
    RobLewis [OP] New Member
    Rob
    PreRunner
    Hello,
    I have 2005 PreRunner and replaced the V-Belt twice since purchasing it, still under warranty. Now I have 80,000 miles and still dealing with the squealing V-Belt. Is anyone else having this problem?
    Rob
  2. Apr 7, 2010 at 10:35 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Are you sure it isn't a bad pulley?
  3. Apr 7, 2010 at 10:42 AM
    RobLewis
    Rob
    PreRunner
    I don't think it's the pulley. It doesn't squeal all the time, nomally when it rains and it continues for a couple days and then stops. Had someone check it out not to long ago and they said the belt look good and it has automatic tension so they couldn't tighten it.
  4. Apr 9, 2010 at 4:31 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    sounds like the Pulley to me. It can still be intermittant if it's the pulley.
    Had the same thing happen to me on a ranger and I thought is was the belt. After belt was replaced still had the problem -- checked the idler pulley and sure enough there was slop in the bearing. $15 and 30 min later problem was solved.
